Question about Bissell Cleanview Powertrak 35933 Bagless Upright Vacuum
Bissell cleanview bagless - dirt doesn't end up in container
Dirt gets sucked up but never ends up in the dirt container - there must be a clog somewhere???
  • taperman Mar 23, 2009
    I have the same problem. If you try to use the hose separately the base shoots dirt in the air, and the hose gets all clogged up. Cleaned out the hose and everything I could find that was dirty but just clogs up again. thanks.
I have a bissell power brush shampoo cleaner, it will not release the soap. what is the problem
Posted on Feb 21, 2009
How do i put the plastic bagless part back
I have an Bissel Cleanview Helix which I think is similar. The lock'n seal lever has to be in the unlock position first. Place the filter cup in first and then the Dirt container next and hold it in place and move the lock'seal lever to the lock position. I hope that this has helped you.
May 26, 2011 | Bissell 8975 CleanView Bagless Upright...
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
Filters are clean but it is telling me that they aren't on the indicator
it may be clogged. did u clean the filter above the dirt cup?
if it still doesn't **** then check the hose for clogs
May 31, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Vaccuum will not ****
Remove the hose from the holder, if you have suction at the end of your hose, then the problem is down below that point. Check the dirt inlet for a clog. Also the belt may have stretched and isn't turning under load. If you haven't replaced the belt in a while, change it and check the brush roll and make sure the ends are turning freely.
If no suction at the end of the hose and your hose is cleat, then the filters are clogged, check all of them.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Don't sucks ditrs
Is the brush turning?
If not, replace the belt, check the brush roll make sure the ends turn freely. Other wise, are the filters clean? The hose and/or the dirt inlet by the brush roll may be clogged.
May 11, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Will not suck
You must still have a clog, check the dirt inlet down by the brush roll(#23) for a clog. Do you have suction at the hose end, if you do, then it is clogged down below. If you don't then either the hose or filters are clogged.
Feb 27, 2008 | Bissell 3576 CleanView II Bagless Upright...
Bissell Powerforce Bagless Vacuum
Either your hose is plugged, or the inlet by the brush roll is plugged. Another problem that can cause this is the the filters are clogged or may just need to be replaced. Most of these has a filter in the dust catch bucket, and also above the bucket. Make sure all filters are clean.
Jan 05, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
133 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
