Question about Frigidaire ATF6000ES Front Load Washer
AL5143VW! doesn't empty water on any setting - any ideas?
The washing machine washes on all settings but stops when it comes to emptying the water and spinning it dry. Changing it to another type such as delicate, etc. results are the same.
    President:
  • 1,902 Answers
Replace the water pump located on the bottom of the unit. You can order the part on repairclinic.com
Posted on Feb 20, 2009
Hja8703 will not drain
before doing any of the below please try not to get any electric wires wet and make sure the plug is off oor better still unpluged....good luck.....tip be carefull not to pull any little wires off......it might have somethink stuck in the pump causing the machine not to empty the water (the pump is normaly found under the bottom of the washing machine) if you do undo the pipe going to the pump watch out because there is water in there most of the time.......also check the filter because somethink could be stuck in there (these are normaly found on the front of the washing machine under the bottom front cover).....be careful because a little bit of water comes out...
May 17, 2014 | Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Mar 24, 2008 | Bosch Axxis WFL 2060 Front Load Washer
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
