Question about ASUS KFN32-D SLI /SAS Motherboard
Unable to see RAID 5 config on Asus kfn32-D SLI/SAS MB
Have 4 1TB seagate drives. Setup RAID5 in BIOS for first 4 SATA ports. Entered Nvidia RAID util and added the 4 drives to a RAID 5 config with 64 bit striping. Cleared the MBR and set as bootable. Creates a 2.72TB RAID array. Got a warning that arrays larger than 2TB require the use of a 9.xx or greater OS driver. Of course Asus does not supply a raid driver on their website for this board. Anyway, created a driver floppy with the cd that came with the board. Booted with the Server 2003 disk and hit f6 for the raid driver. It read the floppy and had two choices, Nvida RAID or reg IDE. Using RAID driver - no drives found. Using IDE - Setup pulls one disk from the array and proceeds to install. Does anyone know if there is a current driver for this RAID that will work? Or is this setup even going to work? Any help would be greatly appreciated.
  • Chuck May 11, 2010
    try not hitting the F6 button and when it goes to install the operating system when it gives you the option to install to a partition see if it shows the full 2.7 TB
First IDE mode will not allow you to use RAID so you cannot use that. NVidia RAID should be able to handle the 2.72 TB RAID volume but there are other limitations you need to be aware of. . MBR which is Master Boot Record is the volume structure used by most windows systems and it has a limitation of 2 TB. You can use the newer GPT instead of MBR, but you cannot boot off of a GPT volume directly on most PC's. To do that you would need EFI (Extensible Firmware Interface) which basically is a new replacement for the BIOS. The motherboard manufacturer would have to support EFI.
You do have a lot of alternatives here though. Given the fact that you have four drives you could use one drive for the system disk, and use the other three for a RAID 5 volume. You would install windows on the single drive and then boot into windows and used disk manager to create a new partition on the RAID 5 volume. The benefit is read access speed and redundancy. There is a write performance hit because of parity generation and the space available for data is approximately the same as the total of 2 drives. The rest of the space stores the parity information. So you end up with 1 TB system drive with no redundancy, and a 2 TB RAID volume.
You could also use RAID 0+1 which is two stripe sets where one is a mirror of the other to provide redundancy. This gives you speed without the write performance hit. With 4 x 1 TB drives, you would end up with a bootable 2 TB volume with redundancy and excellent write and read performance.
Posted on Jul 20, 2010
NVIDIA RAID does not support > 2TB (18xxGB) arrays. It will NOT show up properly in Windows.
Posted on Feb 28, 2009
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I have an Asus SK8V. It is booting off of a 320gb Maxtor SATA drive set with the the jumpers to 1.5gbps because it will not get recognized by the VIA SATA chipset w/o doing that. It is in the normal SATA...
You need to go to ASUS to get a bios update. Since your board only appears to support SATA 1, it probably has the older bios that tops off at about 380mb. drives. (I don't think that a bios update will give you Sata 2 as that is hardware limited)
Mar 09, 2010 | VIA ASUS SK8V MB, 8T800/ SATA/ RAID/...
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
M2N-SLI with Raid and Vista
Hi Eric,
You need 2 hard drives to create a RAID! (Read this).
http://en.wikipedia.org/wiki/Redundant_array_of_independent_disks
Download from Asus the latest RAID driver software for Vista.
M2N-E SLI motheboard.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Hope you find this helpful Eric!
List any troubles or questions....
Mike
Jul 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
Setting up SATA
You need to enter the bios. Use the M2N-E SLI manual to help make some changes. Start up the PC & begin to press the Delete key every two seconds. Doing this will open the bios. Open you're manual to page 4-29. All four SATA's should be set to Disable. Save & exit the bios. The SATA drives will still function but you should no longer get the screen to setup a RAID.
Enjoy!
Mike
May 30, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Sata Config
go to bios settings, usually F2 on boot, then CMOS setup, check that it is there, and if not try to have the bios search/recognize it. Save settings and reboot.
Jan 29, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Sata/raid not working on ASUS M2N MB
You may need to set up the RAID array before it will be detected. Look in the BIOS and see if there is a way to set up the RAID array there. If there isn't, watch as the PC boots up and see if there is an option to go into the RAID settings before windows starts. You may need to actually create an array before it will be seen.
Nov 06, 2007 | ASUS M2N-MX Motherboard
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS KFN32-D SLI /SAS Motherboard Logo
560 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
