Question about Kal Equipment Battery Tester - KAL Equipment
I need an instruction manual for a kal model 4260 battery tester.
  • 565 Answers
I'll tell ya, it sure took some digging to find that one. Evidently KAL Equipment was acquired by Actron.
http://www.actron.com/media/usermanuals/KAL4260_0002-000-2374%20PW_Battery%20Load%20Tester_MNL_Eng.pdf
Posted on Feb 24, 2009
I have a 1992 gmc jimmy on a water access only island. it stands out in all weathers in the Vancouver area of BC. The vehicle is only used at weekends and when parked I disconnect the battery negative...
Cranking and not even trying to fire is usually a fuel pump failure. First be sure it is quiet at the vehicle area. Battery is fully charged. Set in vehicle, radio & a/c-heater off. Turn key to on/run position for 3-5 seconds there should be a faint sound of electric motor (fuel pump) running. Turn key off for 10 seconds & try again. No sound of it running? Then next simple check is to have a person crank the engine while you hit the bottom of the fuel tank in center area with a hammer. Repeatedly hit it with solid hits (not too hard, you do not want to damage the tank) while cranking. If the engine starts the cause is the fuel pump motor failure. This requires to remove the fuel from the tank & lower the tank to replace the fuel pump. You must get at the level below 1/4 tank to safely handle the tank.
If your engine did not start & you do hear a fuel pump 3-5 second prime then you could have a ignition failure. The most common is the coil wire corrosion in the boot and the tower of the coil. Check this at the distributor also. Also check all spark plug wires for corrosion. Best to replace these parts if corroded. If you do not replace them next best is to wire brush and seal with wheel bearing grease or ignition dielectric grease. Use grease on new parts you are replacing also. Sometimes the grease you add causes the boot to seal & air in the boot pushes the boot back off a little. The boot needs to be released of the air in it. Slip a very small screwdriver under the boot while pushing it on then there is a way for the air to escape.
Chris
ASE Master certified sense 1979
Dec 06, 2013 | 1997 GMC Jimmy
Doesn't work Is there a battery?
All of these non-contact voltage testers require a battery. On this one, its located under the pocket clip assembly at the top. Consult the manual page 3 here: http://www.kleintools.com/sites/kleintools/files/instructions/NCVT-1-Non-Contact-Voltage-Tester-Instructions.pdf for instructions on how to install the two AAA batteries.
Dec 04, 2013 | Klein Tools Klein Ncvt-1 Non-Contact...
Im looking for a user manual or instructions for my old pfaff Hobby 4260 sewing machine
Try this link (free download):  http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/Machinespage?OpenPage&Start=1&Count=400&Expand=76&ResortAscending=0&BaseTarget=RightFrame Good luck!
Mar 29, 2011 | PfaFF Hobby 4260
Looking for owners manuel to kal equip 3000 multimeter.
this is the same as the as the actron 7680 so you can find it in actron.com, then go to manuals, then to discontinued products, there you will find the manual
Aug 31, 2009 | Kal Equipment Measuring Tools & Sensors
Rolled hem settings
Here is a link to purchase your instruction manual:
Pfaff Sewing Machine Instruction Manuals
Jan 06, 2009 | PfaFF Hobby 4260
Kal Equipment Battery Tester - KAL Equipment Logo
899 people viewed this question
Top Kal Equipment Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Kal Equipment Measuring Tool and Sensor Expert? Answer questions, earn points and help others
