Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
I bought my Jensen about 6 months ago and installed it into my Honda Accord. I use "FixYa" to get the e-brake bypass code to watch movies while Im driving. I removed it from my Honda installed it into my Acura. It never lost the ebrake code! I watched movies and used the touch screen for the cd player. About two month into it; it stopped working. Currently it plays Cd's, and DVD, sound working, but I have and all Blue screen with the clock in the lower right hand corner. I can touch the screen in random places and the touch screen still works. It strange. Please help!!!!
Hook your green/white camera override wire to your parking wire that should solve your problem
Posted on Feb 20, 2009
  • dopedtf Feb 23, 2012
    I tryd doing that nd it workd but wen I turnd my car off then turnd it on later it didn't work ne idea wats wrong?
Brake llight on the dashboard stays on why?
either you have a brake system fault or your ebrake is sticking most likely your ebrake is sticking on
if it helps leave a good review
May 10, 2011 | 1998 Honda Accord
My remote wont work on my jensen uv10 and i want to bypass the parking brake. Can you tell my how to do it without remote. Thanks
You don't need the remote to bypass the ebrake withe remote use a tago switch to bypass the ebrake hook it up to the pink wire on back of the deck.
May 04, 2011 | Car Audio & Video
Left e-brake on and drove 6 months ago wrecking the cable which leaves the e-pedal down. And now no e-brake. Today rotated the tires and put the truck back on the ground only to find that it will not...
Pull the ebrake pedal up with your foot while pulling the ebrake handle with your hand. The ebrake on the wheel that is locked just disconnect it from the wheel brake! cheap fix
Mar 24, 2011 | 1990 Dodge Ram
Parking brake disable model jensen 9511ts
on the jensens, there is a way to disable the parking brake without having to put a switch on the parking brake wire. the catch is that you will need the remote control to get into the service menu. follow these steps
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
if for any reason yours doesnt offer this option. you can always put a switch on the ebrake wire of the screen.
1. use a 2 wire toggle and wire one side the ground and the other to the parking brake wire on the jensen. then do the pattern on the switch instead of using your ebrake.
Aug 28, 2009 | Jensen Car Audio & Video
In dash dvd player
disconnect the pink wire from the parking brake (the one coming out of radio) and put a switch on it going to ground. turn switch on off on. youll get picture then
Aug 08, 2009 | Jensen VM9410 Car DVD Player
Video wont play
Go to www.google.com then type JENSEN CODE choose the first one on the top.
Mar 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Alpine cva-1005 ps2 not working while ebrake is up
just get 2 toggle switches and wire them up one to the foot brake wire and one to the ebrake wire ....then connect the foot brake wire to a 12 v+ and the ebrake wire to a ground ....then flip the switches as if you were stepping on the brake and pulling the ebrake then releasing the foot brake .... worked like a charm for me !
Jul 07, 2008 | Alpine CVA-1005 Car Video Player
I cant get a picture with my UV7i with or without the brake on
Its very simple splice the power wire "constant power" Red wire.
Next attatch the yellow parking switch wire to the constant power.
wallah... You can now watch movies on your in dash while driving! The deck thinks the brake is engaged
Alot easier then codes and pressing brake pedals and all that jive. They wont do it if your get it installed somewere so you have to do it yourself, its very easy
Nov 05, 2007 | Car Audio & Video
My Video does not work on my Unit
Actually you don't need to do all those stuff.... there's a softcode hack for this one. it would enable you to even play pirated DVDs as well.... ATTENTION TO ANYONE WITH A JENSEN VM9311,VM9411, VM9511TS and/or 9021TS YOU CAN BYPASS THE PARKING BRAKE SECURITY FEATURE FOR FREE!!!! WITHOUT PAYING FOR THOSE PULSE BOXES OR ANY ADDITIONAL HARDWARE!!!!! YES THE LITTLE BLACK BOXES WORK....BUT THEY'RE A SCAM CAUSE YOU CAN DO THIS FREE USING THE JENSEN FACTORY OVERRIDE CODE So if that isn't clear enough, let me further explain. The code is a permanent way of disabling the brake override on the jensen vm series multimedia head- units. There are two ways of doing this: Insert the DVD After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah" 1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen. (What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.) 2) Next, on the main remote press stop twice, then 1, 2, 6, 4. You will now see a hidden menu that says: Region Code Brake Override (I know you're drooling by now) Macrovision (Watch all the burned and pirated movies you want if this option is off) Loader Version Model Version 3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want. This is what you want: Region Code: 1 Brake Override ON Macrovision: OFF When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving..... The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly. 1) Insert the DVD and you'll get the blue screen. (If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.) 2) On the main remote, push stop twice and then 1, 2, 6, 4 3) Push the joystick on the unit SOUTH twice and then click it once. 4) Press SYS SETUP on the main remote twice to save your settings. It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing. I tried to make this as clear as possible. If you have questions, private message me or post here. Best of Luck! By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Sep 05, 2006 | Jensen VM9411 Car Video Player
Car Audio & Video Logo
315 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
