Question about Ovens
I need to put new terminal block in oven so need to know where
I need to put new terminal block in oven so need the wiring diagram
  • 70 Answers
Keep all the L1 & L2 leads to the outside terminals and only the N wires go in the middle.
Posted on Feb 21, 2009
What's the wiring diagram for a GE wall Ovens digital readout
There should be a diagram somewhere on the oven. Usually on the top or back or if not, inside the terminal block cover where the electrical supply wires go into the oven. Make sure its turned OFF before you remove any covers.
Mar 13, 2016 | GE Ovens
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
Oven wont come on
If Your oven wont turn on, then You need to be sure that the problem is power related. Try to test Your device for power, then You replace the power switch of the oven. To test the power of the device. Be absolutely certain the power is turned off before you begin. To do this, check the clock, timer and oven light, and examine the heating elements on all settings. If any of these components operate, you have power. If a wiring problem has short-circuited one leg of the circuit you may have 110 volts but not 220. This means the oven light, clock, and some heating elements may operate on low, but not on high. It also means you have power and could get a jolt. A jolt from 220 volts can be fatal, use caution! Once you are confident the oven has no power it is time to establish if the problem is the house wiring or the oven itself. Check the housebreaker or fuse and then test for power where it enters the oven. If there is a 220-volt wall plug, disconnect the fuse or turn the breaker off, then pull the oven away from the wall and pull the plug. Turn the breaker back on and test the wall outlet. Also check the terminal block, located just inside the back of the unit. This is where the main power cord attaches to the oven circuitry. If your oven is wired directly into the house, the wiring will be connected to the terminal block. Follow the steps above and while the power is off, locate the three-wire terminal block and inspect it for signs of damage, overheating, or melted terminals. Some installations have 4 wires. The 4th wire is a ground for the cabinet. Ensure all wiring is clear and remember not to touch bare wires or terminals. To check the terminals for power, turn the breaker or fuse on briefly and check the terminal block for power across all three legs. Then remove the power at the breaker fuse. If the terminal block is receiving power, then the problem is within the oven and you will need to isolate the problem using the wiring diagram, found on the back of the oven in a plastic pouch, or on the back or inside the oven near the broiler. If the terminal block is not receiving power, your house wiring may be the problem. Should this be the case, you will need to call an electrician.
Hope this information helped You.
Jan 15, 2011 | Thermador Ovens
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
I was gettin a F5 error andnow i get a F3 error
These are both problems with you Temperature sensor and circuit.
I would check the sensor first. You should have close to 1100 ohms. If this checks out good and wiring looks good the relay is integrated into the board so you would need to replace the control. The info below was taken from www.appliancehelponline.com You can also find diagrams there to show you what these parts look like.
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control.
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
F5
Relay safety circuit failure
· Check oven temperature sensor circuit for intermittent high resistance.
· Check lock circuit
· Press Clear/Off and reprogram control. If code reappears, replace control
Note: If all above check OK the F5 code can be a result of a momentary loss of power (Do NOT replace control or lock, check lock circuit)
Mar 21, 2010 | GE JTP15 Electric Single Oven
WHERE THE WIRING TERMINAL BLOCK IS
The terminal block is always at the rear of the oven.
There should be a removeable cover, which will expose the terminal block.
It may be screwed on, or a lift up plastic cover, but it will be there.
Jan 28, 2010 | Ovens
I am just about to disconnect our old oven and have found the live and neutral and am fine with how they connect but am a little unsure as to how the earth will connect to the small earth tab on the new...
You may need to get a wire connector to install on the ground (earth) wire, so it can be connected to the terminal connection point on the new oven.
If one wasn't provided with the oven, some do this as a service, just look at the ground terminal or in the bag with the instructions, etc. for one. If not, you should be able to purchase one, you'll just need to get one that fits the wire, so knowing the gauge of the wire (either Awg or Kcmil size) will make this easier to get the right connector size.
I recommend that a ring terminal be used, so in the event that the fastening screw might loosen, the ring terminal will not fall off the contact point, whereas a fork terminal could and can come off much more easily.
Not having more detailed info about the brand and where you're located, makes further possible solutions difficult to provide, since Fixya doesn't require requestors to provide any info on what country they're in, etc.
Nonetheless, I hope you find this Very Helpful and best regards!
Aug 19, 2009 | Ovens
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Ovens Logo
194 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
