Back to:
Tags:
Definitive PF1500TL+ Speaker
Definitive Tech Subs?
By kcw573 - usenet poster
In my HT setup I own a pair of Definitive Technology BP8's for front, a
Def Tech C1 for the centre and a pair of Def Tech BP1X's for the rear. So
far I have to admit I'm really happy with the sound, though I would like to
get the extra depth which a sub would put out. At the moment I'm looking at
staying with the Def Tech range and was wondering if anyone owned any Def
Tech subs? PF12? PF15? etc.How have they found them? Any recommendations?
Also what prices are being had around the place? (Australia that is)
Cheers
Pete
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Helpful (85)
Jimmy NY
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am in the market for a sub too (budget $750 Canadian or $500US), and
my local dealer has recommended Paradigm PDR10 and Def Tech ProSub100.
I have found lots of reviews and write ups on the Paradigms, but
hardly anything on the Def Techs. They both sound good in the show
room, but I am leaning towards the Def Techs primarily because of
space (it is 3" less wide than the Paradigm counterpart which is
important as I promised my wife I would hide it behind the couch).
This sub is usually mated to Def Tech's complete 6 speaker HT package
(Pro Cinema 100 I think), which has small satellites. My mains are
floor standing KEF Q35'sanyone have any good/bad experience with
Def Tech subs in general? I am confident in Paradigm quality, but
need some reassurance about Def Tech. thanks.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Definitive Tech Subs?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
I have BP10s all around with a C/L/R 2000 for the center and a PF1500 for the
sub. With your system, you definitely need a sub (you might even consider or
at least try setting all speakers to small after you get the sub).
Anyway, I would definitely recommend a Def Tech sub (it's cool 'feeling' the
bass). The only problem I had was it would produced a hum, but this was easily
solved by simply plugging it into the same power outlet as the rest of the
components (and I mean the 'same' outlet, like via a surge protector power
strip, and not a different outlet on the same circuit - that doesn't work).
Basically pick the one within your budget. The PF1500 (250W) is no longer
available. It was replaced with the PF15TL and PF1500TL both with 325W amps
for less cost. The PF1500TL has the same glossy black top as the PF1500 (and
BP10s and I think the BP8s). The PF15TL doesn't have the glossy black top
(there is apparently no other difference).
Sorry, I have no idea what they might sell for in Australia. In the US, the
PF1500 was $1100, the PF15TL is $699 and PF1500TL is $899 (but usually can be
had for around 10% less than that). I think you would be happy with either of
those. (Oh, and these units are heavy.)
Thank You!
Can you Help with these Home Theater Speakers and Subwoofers problems?
I ordered the caps that you specified in your fix. Do you...
hi i have a telefunken surround sound that i cannot get to...
I can't play mp3 and dvds that i copied from my pc. Seems...
Hello, Problem with Panasonic home theatre model SA-HT540...
One of the output transistors shorted, a 2SC3281. There...
Loading problems.
Repair Service
Find Home Theater Spe. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
