Question about LG 10X DVD IDE 452000078
Lg keybo, main screen does not turn on. i didn't drop it on the ground, or in water. the front screen works as usual, but the inner, main screen doesn't light up
  • 3 more comments
  • alyssa7 Mar 13, 2009
    exact same problem/situation, did you ever figure out how to fix it?
  • Anonymous Mar 27, 2009
    didn't drop it or anything either
  • Anonymous Apr 04, 2009
    The inside screen of my LG keybo dos not work. Any help here?
  • Anonymous May 01, 2009
    My screen still functions..( I deleted my inbox) even with my screen black.
    But, I don't understand why it got like that or how to fix ti..
  • Anonymous May 14, 2009
    i have the same problem,kinda but i did drop mine in water,so now my screen is all moving around like some kind of puzzle,
I am having the same problem.
If i could remember exactly how the menue looked, I could delete my inbox atleast so i could read my text messages and reply to them from the front screen.
Can someone please help me?
Posted on Sep 02, 2010
  • wapisay Oct 21, 2010
    if u look up the manual online u can get directions on how to delete all ur msgs so u can start over. Open the flip press: OK, 2, RIGHT button (on top, under the screen), 4, OK. That's it
With mine i usally press a bunch of buttons and it turns on
Posted on Oct 07, 2010
I forgot my lg keybo 2 unlock code
Shut off your phone. Hold the lock button, the up volume button, and the camera button. It should come up with a screen for factory reset. You may lose all your contacts. But you'll have your phone unlocked. Try to lock it with a simple code this time or a simple pattern.
Nov 28, 2012 | LG Electronics - kdo-keybo-b- Keybo 2mp...
How to reset an lg keybo
From Telus Mobility website at http://mobility.telus.com/en/AB/LG-9100-Keybo/device-details.shtml LG KEYBO 9100 Reset your phone to its original state There are several reasons that you may want to reset your phone to the original factory settings. For example, you may be giving it to someone else, or you may find yourself with no other way to resolve a serious issue such as a frozen screen. CAUTION:
Resetting your phone deletes your ringtones, contacts, pictures, messages, and other downloaded content.
  1. From the Home screen, press the OK key.
  2. Select Settings.
  3. Select Phone Settings.
  4. Select Security.
  5. Type your lock code. This is typically the last four digits of your phone number (unless you've changed it).
  6. Select Reset Defaults.
  7. Press the OK key to confirm.
  8. Select Revert.
Your phone is reset to its original factory settings.
If these steps are unsuccessful, visit a Product Care Centre to have your phone inspected. Use our Store Locator to find the closest location.
Nov 19, 2012 | LG Telus Keybo 2 CePhone Pink - Keybo 2
Help! changing drum bearing lg wm2277hw
The best way I can suggest through my own personal experience is to turn the tub upside down withthe spider shaft facing down. Hold the tub up in the air about a foot and drop the whole tub on to the ground letting the shaft hit the pavement. It may take a few times to do it but it has always worked forme.
Hope this helps.
Nov 05, 2011 | LG WM2277H Front Load Washer
My LG Keybo phone will freeze up when i receive a text message about 5 months ago i dropped it in water i took it out as soon as it fell in i immediately took the battery out and dried it with a hair dryer...
Alot of the LG phones have had this problem. My Keybo has the same problem and it isn't because you dropped it in water. Take it to the service place. They may need to replace it or tell you otherwise. Good Luck!
Jan 10, 2011 | Computers & Internet
Lg keybo, front keys don't work at all, and the draft box is always full but you cant read them, says error 2 when you try.
I have the same problem with my front keys, the entire left side doe not wrk. For the 'error' try turning off your phone and then deleting the drafts - it works for me whenever it gets jammedl ike that
Sep 11, 2010 | LG Cell Phones
The screen goes black when I turn it on I dont get the touch pad or the main screen
The screen is spoilt, either you accidentally dropped it too many times or water have seeped through. Try to open up your front phone cover if you dare, and wipe the inner part.
May 04, 2010 | Samsung SGH-U900 Flipshot Cellular Phone
I have the lg keybo and i cant get my sounds to become ringtones this doesn't work with the LG Keybo, only the enV2, Keybo can't save sounds as ringtones. I have been looking for a solution for a while,...
Hiya, my wife has the same phone.. everything works and the way to get your mp3's as a ringtone is what I found easier to do like my LG dare.. which is to edit, compress the mp3 file and send it via text attachment from your vzpix account to your phone, from there you can save the attachment and modify it's use on your phone as a ringtone. Aloha!
May 26, 2009 | LG enV VX9900 Cellular Phone
My LG Keybo Won't play Windows Media Files
look for a freeware program on the net called "Switch"
amazing program
google it and its there.
it converts almost any auido to basically any audio you wish.
only downside i have come across is that the keybo cant handle some of the translated songs,
for example: a few of my tunes sound slowed down about 10bpm
not the worst but 90% of wma's turn out fine mp3's on the keybo
and 100% of wma's turn out great mp3's with the program,
got me?
Mar 24, 2009 | LG 10X DVD IDE 452000078
Lg keybo --water damage
please help me, i cleaned my phone with lens cleaner and it went inside my phone and it doesnt turn on anymore. i put it in rice lastnight and its not working! what do i do !
Mar 24, 2009 | Cell Phones
Computers & Internet Logo
2,214 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
