Question about Dell PowerEdge 1600SC Server
Need to powerup PowerEdge with out hitting the power Button!
We have application that there is no access to the power switch and need to powerup the 1600SC as soon as AC power is applied.
Is anyone aware, if this possible?
  • 2 more comments
  • frank_pedram Feb 20, 2009
    We are looking for Auto Power recovery. There will be no access to the server as soon as mounted inside cabinet.
    We need this option in case of power failure so when the AC is restored the PC will power up without using the power switch. The bios option does not exist in this model, but in Dell optiplex.
    Thanks for your recommendation , but we found the solution. In this type of server in bios if Power switch disabled the server will power up automaticaly after AC restore.
  • 2dcapcom
    2dcapcom May 11, 2010
    underneith the power switch is another tiny switch that is actually being pressed by the nice big button, have you tried pressing that?
  • 51 Answers
Ahhh ok, well in the bios of some machines their is an option to schedule a wakeup time for the PC, and you could also enable Wake On Lan and then wake up the PC remotely from a computer outside of the server room?
Posted on Feb 20, 2009
  • 2dcapcom
    2dcapcom Feb 20, 2009
    ok, this is a situation i have never encountered, i was thinking about taping something over the power button but holding the power button in on most machines will shut the computer off and that is the opposite of what we want, one quick search led me to this, i have never used it but it may be a cheap option, you could try out the trial and see if it does what you want
    http://www.softpedia.com/get/System/Laun...
  • 2dcapcom
    good to know i will keep that in mind if i every come across this situation
How to powerup the motherbaord without power switch
Hello, you can visit the dell homepage
and enter the sevicetag it should be at the back of your machine:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
The pinout should look like this:
You must use the pwrbtn or power pin to power up the mainboard.
Beware of static Electricity
Hope this will help you.
Aug 14, 2012 | Dell Computers & Internet
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Hi WITH THE ZEBRA DESIGNER I SETUP MY S4M FOR A 4X 6 INCH LONG LABEL THERMAL DIRECT BUT PRINTING STARTS ON THE MIDDLE OF THE LABEL AND GOES OVER THE NEXT LABEL TRIED TO CALIBRATE VIA SOFTWARE BUT WAS...
This will make your printer feed out 2-3 labels each time it is turned on or the head is closed to determine the label length.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of NO MOTION (if not, repeat previous steps)
Hit the + sign until you get to CALIBRATION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT (twice) to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Jun 08, 2011 | Zebra S4M Thermal Label Printer
How do i enter in safe mode on my poweredge 1800 ?
If the server is running Windows, you can usually enter safe mode by repeatedly pressing F8 after you press the power switch.
You can also get into the dell utility, which lets you run memory and system tests. To access this, follow the on screen directions during boot up.
Jan 25, 2011 | Dell PowerEdge 1800 Server
After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
SET/UP EXIT
Hit SELECT
Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
Hit the + sign until you get to NO MOTION
Hit SET/UP EXIT to save changes (permanently)
Sep 20, 2010 | Zebra Stripe S400 Label Printer
How does one turn on a Dell 2500 PowerEdge server?
yes u need the key in order to power on the server
Jul 18, 2010 | Dell PowerEdge 2500 Server
Where to plug power button into mother board
Open the case of the server, and look on the side panel that you removed. It should have all of the server options detailed right on the inside of the case for you.
May 22, 2009 | Dell PowerEdge 2500 Server
Dell PowerEdege 1600SC not recognizing IO devices
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Apr 12, 2009 | Dell PowerEdge 1600SC Server
Bootup Problem - Dell Poweredge 2650
Process of elimination? I first thought it may be a power problem but I could not understand the LED flashing (It still maybe a power problem) If you can leave on charge for 4-5 hours more if you can make sure the light is not flashing (That is turn the laptop off at the power switch) Try turning on after being on charge for as long as you can If that does not work it may be the bios with the wrong setting or the Hard Drive is faulty (The more I think about it I think it may the the last issue) Try the other steps first the turn on holding the DELETE button it (I think that is the button to access the bios ) This with work if the Hard is Good or bad)
Jan 22, 2009 | Dell PowerEdge 2650 Server
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
Dell PowerEdge 1600SC Server Logo
625 people viewed this question
Alun Cox
