Question about Yamaha Full-Size Keyboard
Replacement keys for Yamaha CLP-150
I am looking for part numbers and source for key for Yamaha CLP-150 keyboard.
dauphine
  • 207 Answers
SOURCE: the "i" key failed after a coffee spill. want to replace keyboard
No need to replace keyboard. If it really failed than none of the keys would work. Unplug it, turn it upside down, unscrew all the screws, open it up, clean top of he contact board with cloth dipped in alcohol. You can wash plastic parts and membrane manually in warm water with dish washing detergent. After that, wrap it in towel to dry. You can use a hair dryer but from a distance. Drying can take hours unless you work in it. Than just put all back together and screw back the screws. Plug in keyboard.
Posted on Apr 24, 2008
hamhm
SOURCE: Yamaha digital piano clp 170
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170: V8286600 Rubber Contact, 12 keys, D-C#   Qty. 6 V8286800 Rubber Contact, 11 keys, A-C#   Qty. 1 V8286700 Rubber Contact, 5 keys, D-C   Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck, Howard
Posted on Sep 27, 2008
SOURCE: 2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
عزف
Posted on Oct 31, 2008
SOURCE: missing/non-working black key on keyboard
albania
Posted on Dec 03, 2008
  • 1121 Answers
SOURCE: 3 keys don't work on my Yamaha PSR-150 keyboard.
yes. you must change keyboard pad, below the keys, and check for dirt and deteriorated board.
Posted on Oct 30, 2009
Where and how can I buy a replacement keyboard for Yamaha CVP 305M? Thanks, Michael
There is a well documented problem that occurs with the keybed on some of these models due to a manufacturing fault. Take a look at the keys that are sticking. Is the gap on either side of the key the same ? If not then the key normally leans slightly to the left rubbing on the adjacent key causing the sluggish action. The fixing tab at the back of the key breaks causing the spring pressure to push sideways.
You can just replace the offending key but the problem will eventually return. You could replace the whole keybed but this is a very expensive fix.
Keys are around £ 15.00 each.
Replacement keybeds around £ 450.00
Visit www.beckettsmusic.co.uk
Search for VU101 via the search box.
Feb 23, 2015 | Yamaha Full-Size Keyboard
How do i replace one key on Yamaha YDP161?
A YDP uses the same key type as a basic Yamaha Clavinova. As you have stripped the keyboard to reveal the keys take a look at the end where the key hinges. There will be an arrow pointing to one side. You will need to remove att the screws holding the key base (black plastic ) to the wooden base. Slide the whole keyboard back a couple of inches, push down where the arrow points between the keys, the offending key will pop up. Slide forward and jiggle out. Replace key. reassemble. If the tag on the back of the old key has snapped off remove the piece of debris that might be there before refitting.
dan@beckettsmusic.co.uk
replacement keys can be found online
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17431
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
Am looking for a power supply board for yamaha keyboard
Normally if the board is there, I repair failed components. If the board is missing, call Yamaha America parts dept. They MAY have the part you need. That will be the only source of a complete replacement. Power supply boards are usually easily repaired.
Mar 04, 2011 | Yamaha PSR-295MS Portable 61-Key...
Two of my keboard keys got hit by a child. They won't return to playing position. CLP-370
you'll need to open the keboard and check for the keys that has a missing mechanism on it. It usually is a stopper to prevent the keys from "sticking". You can use crazy glue or mighty bond to stick the broken parts together.
Hope this helps
Dec 22, 2010 | Yamaha Full-Size Keyboard
3 keys don't work on my Yamaha PSR-150 keyboard. Is it possible to fix them?
Oct 30, 2009 | Yamaha Music
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
It is a design fault. A technician advertising on the net informed me i can get it fixed by him and yamaha will pick up the fee.
Nov 12, 2008 | Music
Keys not sounding as loud as others
Hi, BHOWDY.
Probably the best thing to do is call the Yamaha service center nearest you. I live in the Los Angeles area, and the Yamaha service center closest to me is in Buena Park. I called them on the phone and told them what the problem was, and they knew immediately what parts were needed and they shipped them out that same day.
The contacts that seem to wear out the fastest are the ones near the middle of the keyboard. On my CLP-170, it's the keys between middle C and the G above that -- probably no more then 4 or 5 keys. However, I ordered replacement contacts for all 88 keys because once you take the piano apart to replace the contacts, you may as well replace all of them.
Good luck, Howard
Sep 29, 2008 | Yamaha Full-Size Keyboard
Good luck, Howard
Sep 03, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
410 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
