Question about Panasonic CQ-C1103U CD Player
Which colors go where in the power cord?
I pulled out my radio and some of the wires came out and i don't know where to put them back.I need a diagram of the wiring harness to know what colors go where.
  • 55 Answers
You Really only Have
* RED....POWER + 12 VOLTS USE VOLT METER OR 12 VOLT TEST SHOULD ONLY HAVE POWER WHEN THE KEY IS TURNED ON.
* YELLOW......ALWAYS HAS +12 VOLTS
*BLACK........GROUNDS
* THE SPEAKER WIRES WILL WILL HAVE 2 WIRES OF THE SAME COLOR (EXAMPLE) GREEN AND THE OTHER WILL BE GREEN WITH BLACK LINE ON IT .YOU WILL HAVE 4 SETS OF THESE .IF THIS IS TO MUCH FOR YOU.. PICK UP THE REPAIR BOOK FOR THAT CAR IT WILL HAVE THE CONN.PIN OUTS. GOOD LUCK.
Posted on Feb 20, 2009
Wiring diagram for back of radio
Do you have a wire loom or want to know which pin on back of radio?
If want to know wire colors please see below:
white front left
grey front right
green rear left
purple rear right
Red + Permantant Power
Yellow. Power only when car on.
Black - Earth
Brown - Phone System
May 03, 2014 | JVC KD-SH99 CD Player
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at www.crutchfield.com Hope this helps.
Aug 23, 2011 | Car Audio & Video
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
May 20, 2011 | Car Audio & Video
I need to know the wiring color diagram for
Radio 12Vorange Radio Ground black Radio Ignition pink Radio Illumination
blue/black Factory Amp Turn-on orange/black Power Antenna green
Left Front Speaker (+/-) red - blue
Right Front Speaker (+/-) white - brown
Left Rear Speaker (+/-) orange - blue
Right Rear Speaker (+/-) orange - green
Mar 07, 2010 | Mobile Authority Car Audio & Video
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
STEREO WIRE CODES DIAGRAM FO A 1998 BUICK CENTURY
need codes to hook up radio to 1999 buick century
Aug 22, 2008 | 1998 Buick Century
Panasonic CQ-C1103U CD Player Logo
250 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
