Question about Maytag Washing Machines
Tub size I can't fint the tub sz of a maytag atlantis mod # mavt754eww. Can any body help?
Buffalo12980
  • 625 Answers
SOURCE: Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Posted on Sep 06, 2007
Jimster
  • 240 Answers
SOURCE: Removing Tub from Maytag Atlantis Washer
I do believe that when you remove the four bolts, it should come out. Sometimes you have to use a little force and shimmy left to right to get it to break loose (no hammers please) especially if you have a lot of scum build-up from soap. They can really be a bear sometimes to remove. Maybe put your foot in the bottom of the tub and hit it on both sides to work it free. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 90 Answers
SOURCE: maytag atlantis leaking in the tub
replace water valve
Posted on Jan 06, 2008
SearsTechToo
  • 261 Answers
SOURCE: Maytag Atlantis loud screech when it brakes the spin cycle.
Hi Scott,
The brake has dust on it from wear. It is at the base of the machine inside the center were the base of the gear case rests. The brake is easy to fix with one catch. There is a tension spring hold it together, never mind the 5/16 hex screws attaching it, there is 200 pounds of pressure there.
Parts 16 to 23 are causing your problem. You need parts 35-2948, 21001161 and 35-2018 which are numbers 21, 22 and 23. While your there tell them you need a spring compressor for this job. Make sure after removing 24 that the compressor is fitted to the shaft and that it lines up to the notch in the shaft so your retention pin holds the spring until you can loosen the stator(23) from the brake, 22.
Posted on Oct 12, 2008
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
Remove maytag inner tub
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Jul 02, 2015 | Maytag Atlantis MAV6000 Top Load Washer
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Leaking from bottom I think there is a hole in drum?
Not likely that there is a hole in the tub. The likely possibilities are a bad seal in the tub, a disconnected hose to the load size switch, or a leak in the drain hose or pump. Pull the front off and look for the leak.
Jan 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Lint on clothes
hi thanks for the question sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let stand for 4or 5 hrs . now drain the tub should work thanks for the question the appliance doc
Sep 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
