Question about Epson Stylus CX3200 All-In-One InkJet Printer
No disk for printer
Got my tower up graded now printer will not when i want to print any thing of the computer
  • 163 Answers
Why is it randomly starting and printing rubbish?
go to control panel on the computer , printer devices , see what is printing and highlight print tasks and delete or cancel all print tasks
check that the printer drives has not been corrupted by going to printer properties and checking for driver updates
If you have up graded the pc with a win 10 upgrade, it could be a compatible problem as to get the best out of win 10 it needs to be installed of a disk as a stand alone os and not an upgrade of an existing os
Feb 12, 2016 | HP LaserJet 1320tn Printer
Every application crashes
hi!!!
try to update your printer driver
here samsung
Sep 22, 2008 | Samsung CLX 3160fn All-In-One Printer
Will not print, can.t find printer
If you are not able to find your printer on your computer, then the simplest thing (but takes time) you can do is uninstall the printer using the companion disk that came along with the printer and install it again. This will ensure that all the drivers are well up to date and then you will be able to print again.
However there are another reasons for not showing printers in the Printers and Faxes folder in Control Panel. 1. Check your wireless settings on your computer. 2. Check the printer by connecting it using USB cable directly to your computer.
If it connects again using the cable, you may need to run wireless configuration once again using the same companion disk.
Cheers!
Mar 27, 2010 | HP Officejet Pro L7680 All-In-One Printer
I can't use printer from computer,all it's saying on the instructions I got was, plug power in and ubs cord to printer,nothing hooked into my tower, go figure???? so how do I do it,it's a new computer,just...
Plug the USB cord from the printer to an available USB connector on your tower, insert printer disk into computer drive, then go through Printer Setup and you should be able to print.
Dec 14, 2009 | HP Ruggedized DC Car Adapter for HP...
I purchased a new HP Compac tower and now my Lexmark printer won'
Here's a link where you can find information regarding Windows 7 support for your printer:
http://support.lexmark.com/index?page=content&userlocale=EN_US&id=HOT18&locale=en&productCode=LEXMARK_X1150&segment=DOWNLOAD&actp=HOTTIPS
Not sure whether the Windows Vista drivers will work on Windows 7 or not, but anyway, here's a link where you can download indows Vista drivers:
http://support.lexmark.com/index?page=content&productCode=LEXMARK_X1150&actp=PRODUCT&id=DR116&segment=DOWNLOAD&userlocale=EN_US&locale=en
Nov 08, 2009 | Lexmark X1150 All-In-One InkJet Printer
Dell 3100cn Printer
Hi Lillie,
No, the message for RAM disk has nothing to do with your issue. RAM disk is an option for that printer, but most users do not have that option, and if you accessed the menu for the 3100 on most of the machines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not mean that your computer is communicating with the printer. In Fact, that message would show up even if you did not have it attached to any computer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the "reports" menu. Select either the printer settings, or the PCL Fonts report. When selected, the printer should print which ever report you selected.
One thing you may want to check is to see if there are any print jobs " locked up " in the print spooler on your computer, and also make sure that the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job that had a problem and is "stuck". This will prevent any job sent after that to be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clicking on "printer" from the menu and ensure that work offline is not checked.
Good luck.
Oct 06, 2008 | Dell 3100cn Laser Printer
Old hp printer won't print anything with new hp desktop computer
Your PC has VISTA loaded (according to the HP web specs)
This printer has no specific driver for VISTA but basic functionality is supported by VISTA without the need to load a seperate driver.
refer HERE
The printer connects via a USB cable to the PC and should be detected automatically by VISTA whe the printer is turned on.
The original CD would have drivers for an earlier vesrion of windows (98 or XP) so you should uninstall any programs that were installed offthe disk.
Post back results or further questions for more assistance
Jul 16, 2008 | HP DeskJet 656c InkJet Printer
Wont work
The issue you have posted does require little more information in order to isolate the issue to fix it. Information like have you installed the printer driver and connected the printer cable to the system in your system for the printer to communicate, are you getting any error messages when you are trying to scan or print, weather you have used the printer earlier and it was working fine till the recent past or it was just being used for sending faxes only and printing and scanning was not tried earlier, However let me provide you few steps that you cold try to fix the issue.
  1. Click on start point Control Panel and click on it.
  2. In the control panel window click on the icon labeled “System”
  3. Click on the Hardware option at the top and then click on Device manager.
  4. On the device manage page check if you have any devices under “Other Devices option with a YELLOW ! mark, if so right click on the device and left click on uninstall.
  5. Close all the windows and then insert the Driver disk for the Printer in the CD/DVD Disk Drive to install the drivers for the printer.
Note: At this point of Disconnect the printer cable if it is connected to the system tower, and do not connect the cable until the installation wizard prompts you to do so.
If you do not have the Printer driver disk handy then you can download and install the printer driver form the link below:
Brother MFC-3340CN Printer & Scanner Driver USB (Free Download)
http://www.driversdown.com/drivers/10429.shtml
Brother MFC 3240C Printer & Scanner Driver USB (Free Download)
http://printers.free-driver-download.com/Brother/25079/Brother-MFC-3240C-Printer-&-Scanner-Driver-USB-v.A-Windows-98-ME.html
  1. During the installation the wizard will prompt you to connect the printer USB cable to the system tower, so go ahead and connect it.
  2. Once the installation is finished restart the computer.
Should you require any further assistance regarding the
printer or even require assistance regarding any other
computer related issue in future please feel free to
contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 30, 2008 | Office Equipment & Supplies
Cannot install hardware dynamic link Library (DLL) initiallization routine filed
The issue you have posted does require some more information to isolate the issue and fix it, information like was the printer working fine earlier and was it installed on the same computer that you are installing it now, did you up-grade your systems operating system, what is the operating system that is installed on your computer and so on, however let me give you few steps that could fix the issue with the best of my expertise’s according to the error message that you have posted. I would appreciate if you could perform them to fix the issue.
  1. Disconnect the printer for the system tower.
  2. Click on start point to control panel and click on it.
  3. Click on Add/Remove software icon.
  4. Locate the printer All In software in the list of soft wares’ displayed and click on it and then click on remove.
Alternately you can also uninstall the printer using the Printer All in disk installation wizard.
  1. Close the Add/Remove window and in then locate the System icon in the control panel and click on it.
  2. Select the hardware option at the top
  3. Click on device manage.
  4. Locate other the option devices if present and check if there is a yellow ! mark. Right click on the other devices with the yellow ! mark and left click on uninstall.
  5. Close all the windows and then insert the Printer All in one disk in the Disk drive (CD/DVD ROM).
  6. Once the installation wizard is up click on install and follows the onscreen instructions.
Note: Please do not connect your printer to the system tower until the installation wizard prompts you to do so.
11. After the installation is finished restart the computer.
Should you require any further assistance regarding the printer or even require assistance for any other computer related issue in future please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Dec 06, 2007 | Dell 942 All-In-One InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
19 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
