Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Our GE electric stove was working fine and then suddenly the burners and oven elements stopped working. The clock and indicator lights come on but no heat in any of the elements.
  • co_curls Mar 13, 2009
    I have the same problem. My stove was on and only one burner. Then everything went out. The lights would come on, but there was no heat out of the oven or the burner. I flipped my circuit breaker on and off with no avail.
  • im2hot25 May 11, 2009
    Circuit Breaker tripped and now neither the top or oven will heat everything else on breaker is working fine (GE electric Smoothtop)
  • 198 Answers
Check circuit breaker
Posted on Feb 20, 2009
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Burners, oven will not heat, all lights work
Sounds like you are only getting 120 volts. All heating elements require 240 volts to operate. Start by taking the covers off the back of the range and looking for loose or burnt off wires. Look first at were the range cord connects onto the range. If all OK with range wires, check wires inside range receptacle (where the range cord plugs in) and also the connections on the household circuit breaker or fuses. If you use a meter to test for 240, you may see it, but if a connection is poor, it may not be good enough to supply the required power.
Oct 02, 2008 | GE Spectra JBP78 Electric Kitchen Range
Burners not working and stove only heating up to MAYBE 100 degrees
Had a similar problem...it was the power coming into the house and the ground wire was badly connected. The power company checked out the lines feeding the house and discovered the problem. Its caused by the fact you are trying to heat the stove with only one line...when, you need two. Check the house circuitry.
Jul 16, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
333 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
