I have a Samsung 42 S42AXYB02 the the picture is mostly with and then sometimes the picture looks alright. It comes and goes.
  • 1 more comment
  • eddieellisor Feb 20, 2009
    Rocfixya wrote "unplug the unit for a long time and check again" for a fix.....
    That's ****. Done that already. It's still broke. I need so real help.
  • eddieellisor Feb 24, 2009
    Samsung S42AXYB02 Flat Screen. The colors are all fuzzy and white then sometimes you can make some of the picture out but then it goes back to a white out state, with orange pixels down the left side. I believe that one of the circuit boards is failing but which one? Any of the boards look simple to switch out but I just need to know which one.
    It says Sylvania 6842THG 42-Inch Plamsa HDTV with Speakers on the front but the sticker on the back says samsung S42AxYB02
  • 564 Answers
There is no problem with your TV.  Call your cable provider to check the connections. to get clear picture there should not be any problem with the cable.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Feb 24, 2009
    Sergeant:
  • 250 Answers
Its the problem in the main pcb circuit board of your tv.as some pof the minute components are got weak or getting short in between.as you turn the tv on the picture is perfect but because the components are weak or got loose or short in between they gets over heated and the picture turns off and screen goes while and fuzzy.you will need to get that faulty components on the board replaced.just do not on the tv till it get repaired to avoid the further damages.
  • 265 Answers
There is no problem with your TV so there is nothing to worry about, it will be becuase you are most likely using SKY or a Freeview box, you dont get the images in HD. you just see it as a normal tv screen. IF you was to upgrade to SKY + HD you will see crystal clear picture.
Hope this helps
    Sergeant:
    Champion:
  • 289 Answers
Hi..then there will be a problem in the video circuit
board which will lead to to this failure.This is the
common failure for this problem.
check this out..
thank u..
rate me..
  • Hariharanath V Feb 24, 2009
    hi..this problem is due to the video circuit
    board.
    check it out..
    thanks..
    hi..the problems such as convergence,pixels,
    negative colour is due to the video board.
    thanks..
    Scholar:
  • 165 Answers
Its the problem of convergence in the main board of the tv.there the ic is short and also cjeck out with meter for anmy faulty capacitor too.it will be bulged or slightly bursted from its top.
  • 679 Answers
Unplug the unit for a long time and check again.
Posted on Feb 20, 2009
Samsung LED tv
The power supply board probably needs to be replaced. Sounds like a loose solder joint on the board
Jul 05, 2016 | Samsung Televison & Video
I have a Model HLT5055WX/XAA that will turn on, but shortly after coming on the picture goes out. Audio still works but picture goes out and the lamp turns off. I think i need to replace the lamp but am...
Sometimes you have to gamble, lamp most likely--at least look at the lamp and make sure the glass pillar in it is not at a angle etc.
Sounds like you have taken all the easy steps, hate to buy a lamp you may or may not need but since wheel is ok the lamp or ballast are most likely.
Dec 16, 2012 | Samsung DLP HL-P5663W 56" TV
Ps-42s5h plasma goes black when warmed up.
we ( technicians ) call it a cold solder or burnt solder , just need to open the tv and give a VISUAL look thru the entire PC Board , good luck , AJ
Nov 05, 2009 | Samsung PS42P2S 42 in. Plasma Television
A 42 or 46'' Samsung picture shuts off but still has sound
Remove all video inputs including hdmi if problem goes away. Determine what input is suspect and call smasung for a firmware upgrade. HDMI casued intermittant behavior with this series, but was sometimes seen on component video.
Jun 29, 2009 | Samsung DLP HL-P5663W 56" TV
Volume intermitently goes off but still have picture
Is this problem solved? I have it now, so I need the solution asap!!
Jun 22, 2009 | Samsung Televison & Video
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
When i switch my samsung lcd tv model le32r87bd it starts alright but after about 2 seconds the picture goes and the screen turns black i can still hear the sound and the remote seems to still work but no...
Sounds like you need an inverter board which is the power supply for the screen lights. I tried to look up the part but samsung dosen't have a service diagram posted for it yet. Since it is so new you may want to find a samsung authorized service center because if the part is not available yet Samsung will have to solve the problem.
Jun 27, 2008 | Samsung Televison & Video
No picture
hello
Seems to me that your power supply has weak 330 or 470 Mfd 200 volt capacitors.
Use computer grade Caps
I would have them changed first.
Thanks Guy9
May 07, 2008 | LG 42LB1DRA 42 in. LCD Television
Funny lines that come and go
Call for service immediately. Usually this relates to a flaky power supply or picture drive module. Electronics usually either fail when they're very new or very old, so this isn't that surprising.
Could also be transport related, as these are big heavy boxes and the damage could come from being dropped.
Feb 15, 2008 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
