Question about LG 42LC2D 42 in. LCD HDTV
Low sound on LG LCD 47" hdtv
I have this new LG HDTV 47 " mounted on a wall, I have to turn the volume to the maximum, and I still can't hear the program correctly. Anyone with the same problem, any ideas what may be going on?
  • May 11, 2010
    Are you using this with a cable box or satellite receiver?
    Problem Solver:
  • 19 Answers
Alright, here's a few things you can check.
1) As the clarification request asked, is there a cable or satelite box involved here? You may need to adjust the volume of this device seperately to recieve optimal audio.
2) If #1 is not the issue, you may wish to make sure that all your cables are properly and firmly connected. A loose connection could be responsible for this.
3) Try it on a different input. You may have a faulty input on your TV, in which case this would indicate a bad main board with problems in audio processing
4) If you're sure it's not your cables and cable box or whatever, you may very well still have a bad main board in your TV that isn't producing loud enough volume. Alternately, you may have speakers that are improperly connected or bad.
If it is in fact a faulty main board or speakers within the TV itself you'll have to seek professional assistance to fix this if it's under warranty, else you'd void it out by preforming an unathorized repair to the system. If it's under warranty from LG still it shouldn't be an issue and parts/labor should be covered for this.
If the unit is not under warranty to repair this you'll need to find either the speakers or main board assembly to replace into it. Ebay seems to have lots of misc parts. Google may also yield advice, or alterantely you could purchase directly from LG themselves.
To fix a main board issue you would have to remove the screws holding the rear cover in place. There are about 20 of them, give or take. You'll want to take note of where they came from as some are designed to be screwed into the outer part of the casing around the edges. Those are the screws for the plastic sections, the thread is looser on those. The sheet metal screws have a tighter thread to them and are the ones usually located in the 'interior' of the rear panel. Also, remember to unscrew the tiny screws around the inputs. They also need to come off.
Now, once this is done you would need to remove the screws holding the main board assembly into the panel. The main board is the board with all your component inputs on it. It handles all your video and audio processing, really. Take your screws out, pull your connecters(Gently! Carefully! Do not accidently pull a wire out or you'll not be happy later, trust me) and pull out the board. Place your new board into the empty space and reverse the directions. However, I recommend prior to sealing up the back panel plugging in your power cable, turning your TV on and doing a test run beforehand. Just to make sure you've properly connected your stuff back up. It would **** to get that thing mounted back on the wall, turn it on and then realize you forgot to reconnect your LVDS cable.
If it's a speaker issue and you're going inside the back of your set, doublecheck your spade connectors and make sure they're tight. If the speaker is blown, bad or weak it should only be a few screws(2-4 depending on the interior of your model) and the two spade connectors holding it in place. Pull the screws, pull your speaker, detach the connectors, reverse to install new.
Posted on Feb 21, 2009
No volume sound very low at maximum
Look both at the set and the Box if used (cable or sat) to make sure volume is not turned down---also a receiver if used can do the same thing.
A quick low tech test is do you have the same problem when playing a DVD etc.
Apr 24, 2012 | LG 42LC2D 42 in. LCD HDTV
My Vizio SV472XVT 47" HDTV
Unplug the TV from the wall. There must be something wrong with your circuit board. Call customer service for what to do to fix your TV or get a new one.
Mar 05, 2011 | Vizio SV472XVT 47 in. LCD HDTV
I have a 37 hd Lg and a 47 hd lg the 47's sound absolutly sucks the 37 sounds are much better. I don't always use the sound system I fell I should be able to hear regular sound after spending 1800 bucks...
Hi.
My answer depends on the model and on what you mean by saying that the "sound suc.ks".
LG is not known for having the best sound performance on earth, but the sound is by default audible with a decent stereo quality and surround sound (absolutely no cinema quality).
Check sound settings, and ensure that the voice filter is not on.
If that does not help, then get back to me, give me model for the 47'', and possibly give me some more details on sound malfunction (eg. broken sound, no bass but lots of mid tones, low volume, no surround etc.). Some of this symptoms may be normal, depending on the LG model.
Regards.
Ginko.
Oct 31, 2010 | LG 37LG30 37 in. LCD HDTV
Problem for LG 47LC7DF 47 in. HDTV LCD Television it just flashes red and takes a couple of minutes to turn on and makes a popping sound..
television just flashes red and takes at least 15 minutes to turn on after turning off and on and makes a popping sound.
Apr 24, 2010 | LG 47LC7DF 47 in. LCD HDTV
I have a shadow on my 47" LG LCC7DF HDTV LCD TV
This is usually caused by dirt trapped between the lcd filter layers and appears when the screen is pressed, pressing the layers togehter producing an internal dust smear..This can only be removed by stripping the lcd down and cleaning the filter layers
Oct 17, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG 47 External Audio Control
This is the only way a bose works
May 01, 2009 | LG 47 in. Flat-Panel LCD HDTV
Lg 47 inch tv sound
We had the same problem of pathetic sound quality and volume with a sony brava. Thats just the way they make tv's these days because most people buy a surround sound system as well. We bought logitec computer surround sound speakers for about $140 and plugged into the ear jack, problem solved, we have heaps of volume and stacks of bass.
Dec 21, 2008 | LG 47LC7DF 47 in. LCD HDTV
47lc7df
I ordered a Sanus VMB1 kit for the some problem and I believe it should fix it for mine.
Oct 10, 2008 | LG 47LC7DF 47 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
585 people viewed this question
Computer Repairing
Computer Repairing
