Question about Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard
Intel d815/eea2 powers up but does not boot - Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard
  • 530 Answers
Hi im josh in cebu phils. if it turns on but not boot. the problem is no set boot sector is selected. friend try to enter bios set up and then go to boot menu. then select hard drive to boot first.then save the changes then restart the pc. if nothing improves open your pc check the ide or sata cable if it is ok.no cut not losen.try to tighten firmly first then turn on your pc. if it doesnt work the same try to change the ide/sata cable and dont forget to give power supply on your hard disk.ok. good luck
Posted on Feb 21, 2009
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
Front panel setting Intel D815 Motherboard
Goto the Intel download site (Click here) search for "D815EGEW" and download the PDF manual. Connection diagram is mentioned in detail in that manual.
Jun 22, 2011 | Intel Desktop Board D815EGEW...
No bios booting on start up
The model number you provided is incorrect.
It is most likely, D945GCNL. Intel site for your MB; http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
If you’re currently using 2 DIMMs of memory remove one DIMM. Open your manual to page 11. First remove DIMM "L". Attempt booting your system. Listen for possible bios beeps. Than shut the system down and remove the memory from " K " and insert your second memory DIMM. Again, boot system and listen for bios beeps. Intel suggest when installing memory on to the D945GCNL motherboard that it be done in a specific manner. See, 1.4 System Memory Page 16, in the TechProdSpec.pdf manual provided below; http://downloadmirror.intel.com/15115/eng/D945GCNL_TechProdSpec.pdf
The power supply currently in your system with does not provide enough wattage for your motherboard. To help find how much power you do need open the next link provided; http://www.journeysystems.com/?power_supply_calculator
It’s better to have more wattage power than you need. Even though you have an Intel manual for your board it’s suggested you download it from Intel. You'll need Adobe reader to view the manual. With Adobe you can use the zoom in feature. The next pdf link is your manual;
http://downloadmirror.intel.com/15115/eng/D945GCNL_ProductGuide02_English.pdf
I do not think there is anything wrong with you bios or your system memory. I think your system is under powered.
Happy holidays!
Mike
Dec 20, 2009 | Intel Motherboard
Intel Mother Board D815 Display Problem
If this is onboard graphics then it sounds like the onboard graphics card has died or gone so best option if it has a graphics card slot ie AGP or PCI Express then to get a dedicated graphics card and that should do the trick.
If not then there is something more sinsiter that is wrong and will be easier to get a replacement motherboard ( the exact same one or one that is similiar that will support the RAM and Processor you currently have )
Apr 28, 2009 | Intel Desktop Board D815EGEW...
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
D815 led and etc pins
Looking at page 85 in you're user manual. The 15 pin jumper block. Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G. If you need the manual you can download it from this link.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
Included below is a small pic.
e8e7d5a.jpg Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Good Luck!
Mike
Unable to boot from USB fey on D850MV Motherboard
Download updated bios here
follow instructions carefully to update bios
use the F8 key right after power up to select boot device.
May 09, 2008 | Intel D850MV Motherboard
Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard Logo
178 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
