Question about Intel Motherboard
MY PENDRIVE IS NOT GETTING DETECTED
Neither my pendrive nor any device which has to b connected through an usb port is not gettin detected
  • Daniel Florin
    Daniel Florin May 11, 2010
    check to see the driver's if they are ok.
  • Daniel Florin
    Check to see if there are all driver's instaled in your pc.take look in DEVICE MANAGE open COMPUTER MANAGEMENT than Go to DEVICE MANAGE .or maybe yor USB IS DISABLED
  • 530 Answers
Hi im josh in cebu phils. friend if not detected the problem is you usb port or the flash disk. if you tried using your flash disk in other computer and you are sure that it is functional. then go to your usb port.check the connections.check also the confg.from the device manger if the printer port works. then dont forget that windows 98 and older versions of windows dnt automatcaly detect usb.good luck .
Posted on Feb 21, 2009
My pendrive not detecting
hi guest welcome to the forum! 1.if u r using win 98, u have to install drivers for the same pendrive watever u r using...
2.if u r using win 2000 or xp or vista, u need not to install the pendrive,but check out tchat ur usb is enabled or whether is working properly by hanging out at the DEVICE MANAGER.
You will get a clear idea when u get on the DEVICE MANGER..
if u dont get the usb ports on DM, then u checkout for hardware trouble shooting..
all the best..
May 19, 2010 | Health & Beauty
Realed to Trasient 4 GB pendrive - malfunctioning
maybe the usb port is not active or disabled or the pendrive is defective, if its still under warranty try taking it bqack to the retrailer
Feb 15, 2010 | Transcend (589307) Media
My front USB port do not detect nothing.so i use the back USB port of the CPU.my collegue has complained that his pendrive has been damage by the front USB port.is this true?
This is only true if the wires connecting the front USB port to the motherboard are connected incorrectly.There are 2 pairs of wires for each connector: one for the +5V & -5V (power) & the other one for the signal itself. If those are not connected properly, the power connectors could be connected to the signal, in which case if a device is connected to the port it will get damaged.
To connect those connectors properly, you have to refer back to your motherboard's manual.
Nov 16, 2009 | Intel Motherboard
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
USB Port not Detecting any Devices
Before i can suggest any steps i need to know since when u have this pblm and what are the softwares and hardwares you had installed recently,please revert back with details for more assistance......:)
May 16, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Recognized my 4gb transcend pendrive
Try windows repair, it should fix the problem.Else connect the pendrive and check the port settings.You can check for the port settings by
right click on "my computer"-->properties-->hardware-->device manager
A new window opens and at the bottom probably you'll find "Universal Serial Bus controller". Expand that option and check whether all the ports are enabled.If the pendrive is still not detected, then the problem is with the port.Check the same with the other available ports.Any further doubts add comments.Would be glad to answer.Good luck.
Jan 21, 2009 | Transcend (589307) Media
USB device malfunction
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Thanking you
M. Sridhar
Jan 18, 2009 | Intel Motherboard
Usb port ceases to work when any device connected to second port
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Jul 29, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Pendrive
You need to install drivers for USB. Also driver file for detecting your pen Drive for Windows 98.
Best Regards
Rafique
Jan 01, 2008 | Epson LX-300 Matrix Printer
Intel Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
