Question about Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 205 Battery won't charge. A few
Garmin Forerunner 205 Battery won't charge. Reset doesn't work. A few day's ago I could use him for hours. After I turn him of, I couldn't start him, or charge him. There is just nothing to see on the screen. Warming him up doesn't help. Please help!
  • 1 more comment
  • gennylyn Feb 21, 2009
    I have a similar problem. It wuoldn't start, charge or connect to my PC. Hitting mode/reset at the same time follwed by the on button got it to start, but did not fix the other two problems.
  • Anonymous Apr 18, 2009
    My 205 will not start either. I bought a new cradle thinking it was bad but it still does not work. Turns on fine but will not charge nor will it talk to my computer. Have had it over a year with no problems and now it just has stopped recharging. I have no solution.
  • garminuser1 May 03, 2009
    I have the same problem, too.  Garmin was fine yesterday, was charged full in the cradle connected to the computer - today - nothing.  Can't get it to turn on or anything.  Wondering if the lithium battery needs to be replaced?  I guess you have to send it back for that?
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Posted on Dec 10, 2010
  • ebike Feb 11, 2011
    I tried this and it still comes up within a few seconds saying battery charge complete yet when I power it up it off the docking cradle it says battery low.
I had the same problem, the unit face was a bit loose and when I pressed the edges down while the unit was on the charging cradle, the charging notice appeared. But when I released the edges, the charging stopped. So I opened up the unit, cleaned the edges the super-glued the face back on. The Garmin charges fine now.
The face is easy to pry off, I think the plastic housing gets distorted over time and the top face doesn't seat very well. But super-glue worked well in this case, hopefully it'll last.
Posted on May 28, 2010
    try the testing and contact cleaning per this site
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
Garmin 295 forerunner will not turn on
Did you mean the Forerunner 205?
It is most likely that the battery has died in the unit or there may be a problem with the battery charger.
The internal battery in the Forerunner 205 is not user replaceable and the unit would need to go back to a Garmin repair for replacement.
Please call Garmin Tech Support for assistance.
Feb 29, 2012 | Garmin Forerunner 205
Garmin forerunner 205 will not stay OFF and none of the buttons respond.
Yes you can restore your data from the TC after a hard reset. You have to go thtrough the setup menu like chose which language etc first.
Well I have exactly the same problem as you and a hard reset did not work either ...
Upgrading / downgrading the firmware also did not work.... the thing keeps on switching itself on regardless....
Do you have found out something more in the mean time?
Feb 16, 2012 | Garmin Forerunner 205 GPS Receiver
Yesterday i download the forerunner 205 software from the garmin website. after i connect my unit using usb to the computer, my garmin won,t power on immediately. i tried to reset it (soft and hard reset)...
Did you install the software correctly? Because such errors appear usually when the update/upgrade is not finisher or was not done in a proper manner.
If possible try to verify the device on another computer (a friend's) to see if the same problem appear.
If the problem persists I'd say you've burned out your battery (hope not the hole Forerunner...!).
Mar 05, 2011 | Garmin Forerunner 205 GPS Receiver
My forerunner 205 was charging just fine until I pressed the power button. The screen went blank and I cannot turn it on. Does this mean the battery needs to be replaced. If so, how does one go about...
Probably it is not due to the battery.
Your device is crashed. Perform soft reset :
press & hold mode plus lap/reset keys for 10 seconds, release then press start long enough until device starts.
Sep 26, 2010 | Garmin Forerunner 205 GPS Receiver
How do i change the battery in a forerunner 205
First, here's the link for the owners manual for your Forerunner 205 GPS Receiver:
The only battery replacement instructions are on page 65 of the owners manual:
Feb 07, 2010 | Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 201
Try a reset. Hold the reset and power button for 30 seconds.
Mar 11, 2008 | Garmin Forerunner 201 GPS Receiver
Garmin Forerunner 205 won't power up
Awesome! MODE + RESET works!
I woke up this morning and found I had a charger death again. It happened two years ago, and I couldn't remember what I did to fix it then.
Mar 10, 2008 | Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 205 GPS Receiver Logo
6,893 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
