Question about Kenmore Oasis HE 27082 Top Load Washer
Pump installation How do I install a new pump to replace broken pump.  I already have the replacement pump
  • jaimeepearlm Feb 20, 2009
    Thank you, i will keep you posted
  • 198 Answers
Remove the back of the machine, This will access you to where the pump is. One wire plug on pump and 2 hoses and a couple of screws removes the old pump
Posted on Feb 20, 2009
Will crank but won't start no revs. Help! Just had fuel pump replaced, and have had new engine previous
How many miles do you have on the new engine? Did you install it yourself? Was it a long or short block install? Was the timing belt on the replacement engine new? Does the engine crank over faster than what would seem normal? If your engine has more than 80K miles on it, you may have a broken timing belt.
Dec 31, 2013 | 2004 Kia Rio
Have an 2004 4.7 V8 Dodge Dakota truck. Truck had no fuel pressure on arrival. After installing 2 new pumps still only had 20lbs pressure. I did not install the complete pump assembly with the regulator...
This is a returnees fuel system. As you mentioned the fuel pressure is regulated at the fuel pump module. If you don't have pressure after replacing the pump and you did not replace the module and you installed two pumps already than the problem is likely the regulator in the module. Replace the whole assembly!
Apr 11, 2013 | 2004 Dodge Dakota
Replace power steering pump on 06 chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Jul 08, 2012 | 2006 Chevrolet Uplander
I have a 2000 nissian altima GXE for which I have replaced the radiator once already and it is leaking again. Any suggestions?
When you replaced the radiator, did you flush the system and install a new thermostat? Also, did you replace the old radiator with a new one, or a re-manufactured one? Try flushing the system, install a new thermostat, and install a new radiator. If this happens again, it may be time for a new water pump.
Jan 25, 2011 | Nissan Altima Cars & Trucks
The dishwasher will not pump water in or out of the appliance.
If the appliance was recently installed, be sure the plug at the food disposer was removed. If the appliance was installed long time ago, check if glass or foreign objects are jamming the pump. If not, perhaps it needs a new drain pump.
Nov 05, 2009 | Asko 1385 Dishwasher
Dishwasher will not drain. had to install a pump kit because the macerator blade had stripped off. It rinses good now but still will not drain. The drain solenoid works well
OK, check the following areas to combat this issue further.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 18, 2009 | GE Dishwashers
How do i replace the fuel pump in my 1993 mazda 626 2.5
1. Relieve the fuel pressure and disconnect the negative battery cable.
2. If not already removed, depress the clips on each end of the rear seat cushion and remove the cushion.
3. If not already done, detach the electrical connector from the fuel pump/sending unit.
4. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
5. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
6. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
7. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
1. Attach the sending unit to the fuel pump assembly and install the nuts. attach the sending unit electrical connector.
2. Install the fuel pump/sending unit into the fuel tank with a new gasket and install the mounting screws.
3. Connect the fuel supply and return lines.
4. Install the access cover and the mounting screws.
5. Attach the sending unit electrical connector.
6. Position the rear seat cushion over the floor, making sure to align the retaining pins with the clips. Push down firmly until the two retaining pins are locked into the rear seat retaining clips.
7. Connect the negative battery cable, start the engine and check for proper system operation and for fuel leaks.
Jun 13, 2009 | 1993 Mazda 626
Power steering pump 1991 Seville
Drain pump.Remove pulley off with removal tool. Remove pump from vehicle. Replace with new pump. Replace pulley with pulley tool.Add PS fluid. Videos available online to show how to do for free. Auto stores with loaner tool programs for free with deposit. Cost myself $100 to do myself compared to $400 shop wanted.
Mar 19, 2009 | 1991 Cadillac Seville
Kenmore Oasis HE 27082 Top Load Washer Logo
204 people viewed this question
Sal De
 Brian Main
Brian Main
