Question about Kodak EASYSHARE 5100 All-In-One Printer
Code error 3607
I justb changed my printhead inmy kodak all inone printer 5300 an it comes up whith a caution code 3607
5 Suggested Answers
SOURCE: Kodak EasyShare 5300 Printer error message
Ten Step Process to Fix the "Print Head" Error Message on the Kodak 5300 Printer.
1. Clear a good spot it your back yard that is free of shrups and flowers.
2. Get the following tools: Flat head screwdriver, shovel, sledgehammer.
3. Dig 24" x 24" hole in your back yard and rope off the excavation area for safety.
4. Whaaaaack the heck out of the Kodak 5300 with the sledgehammmer until such time that it is not a recognizeable piece of electronic equipment.
5. Stab it with the flat head screwdriver, just in case it has the Terminator syndrome (comes back to life).
6. Throw the piece of garbage in the recently excavated hole in your back yard.
7. Cover up that useless piece of garbage and forget you ever owned it.
8. Get in your car and go to the nearest electronic store and ask to speak to the manager.
9. Ask if they sell the Kodak 5300 printer. If so, whack him with the shovel. You don't want to seriously injure him so don't even consider the sledgehammer of the screwdriver. After all, its not his fault that his company carries such garbarge. But the whack is just to burn off some steam from your frustrations.
10. Purchase any other printer but a Kodak and live happily ever after.
Posted on Jul 13, 2008
  • 96 Answers
SOURCE: kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Posted on Jul 21, 2008
SOURCE: Kodak 5300 Printhead problems
Contact Kodak! I received a new printhead and that solved the problem. Great customer service!
Posted on Sep 02, 2008
  • 3 Answers
SOURCE: How do you remove the printhead of a Kodak EasyShare 5300 printer?
Clarification: Remove tanks(cartridges)first. You see the bullseye target with a finger pointing to it.
Above the bullseye sticker, there's a rectangular button. Press it in until printhead dislodges.
Posted on Sep 18, 2008
I have tried what is suggested , I am not getting anywhere with this. I wasn't able to move my finger to the left of anything. What am I doing wrong!
TY
LindaPNY
Posted on Sep 22, 2008
When copy, print scan a blank paper comes out...why? Replace new ink cartridges and tryied to callabrate...no success....at one time a Kodak services #F555951, and error code 3607 registered.
have you done the media sensor calibration? You can do this by press menu button on yoour printer then scroll down look for media sensor calibration., The purpose of media calibration is to detect the paper that you are using to your printer., MOst of the time do ing the calibration will solve issue., Now if you still encounter same problem ther might be a problem on the printer or on the pritnhead., You need to call kodak 1 800 421 6699, I think the printhead is free of charged you may request for printhead replacement
Nov 16, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
What do error codes 3501,3502,3515 mean?
1. im not exactly sure
2. from the factory?
3. call 1.800.421.6699
also, i think the codes are related to your printhead
Jan 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
After 2 0r 3 items are printed it shows me an eror code of 3809
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
Jan 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to change printhead on my kodak 5300
8f42d6e.jpg Under the upper lip of the Printhead the release botton is there. It is on the side where you put the Black ink cartridge.
Jan 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak all in one printer instalation error codes
Jul 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer
1-Deep clean and calibrate the printhead
2-Try a firmware update @ www.kodak.com/go/downloads
3-Try a removal and reinstall of the printhead and inks
If all this fails, call Kodak Aio support : 1-800-421-6699 (USA)
Jun 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Jun 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 printer
K...Trust the solution. Try these steps. Open the printer, remove the ink and remove the printhead (See User's guide). Reseat the printhead and the ink cartridges. The printer will come up with an error message that requires calibration. Do the calibration and scan the sheet that prints right after by pushing the start button. In the menu options, clean the printhead. Do one basic and one deep. Print a demo sheet (another menu option) to see if the quality has gotten better. If it has not call Kodak AiO Tech support. You will need a replacement printhead.
Apr 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Return the printer to the store. I had to do it myself 3 times. First I got a 5100 with the printhead error, got a replacement the day after the scanner was producing distorted  image. Upgraded to a 5300, the scanner wouldn't work at all.  To avoid problems get yourself a Canon or Epson.
Apr 11, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
520 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Michel Smith
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
