Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a Honda generator model Eg1500c. It seems ok....120v 60Hz..but occasionally the motor acts as if it is under a very heavy load and the voltage goes up to 200+ volts. The brushes look good and the capacitor is good.
  • 169 Answers
It sounds like there may be an intermittent short in the output or the stator windings. You'll need to carefully check for bad insulation between the winding and ground, I'd use a megger for this.
Posted on Feb 23, 2009
Output voltage adjustment
Output voltage is based on 3600 rpm @ 60Hz. Sounds like your generator is over speeding slightly. Put a Frequency meter on the output of the generator and tune it to 61.5 Hz, that will get your generator in the 3600 RPM range.
Jul 17, 2014 | Dewalt DG7000 Heavy-Duty 7000 Watt Gas...
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Is it possible to lower the output voltage? My unit is running closer to 127vac?
The voltage runs that high when there is no load so that as you load it the voltage will not dip too low...usually the higher voltage will give less trouble then low voltage will.. you also will use less amps. to run anything at a higher voltage... this places less stress on the generator...
I would not mess with it...when it is fully loaded you will be down under 120v
Sep 11, 2011 | Briggs & Stratton Power Products 5,550...
When you put a load on generator it powers up and down and tries to cut off.
sounds like you are trying to put too much of a load on your generator. I have a 3500w generator and when I hooked it up to my 120v (not sure how many HP) well pump when the pump would try to cut on the generator would bog down and even die. took off the load and started right up. will run other things just not heavy loads. maybe you need a bigger generator for what you are trying to power.
Oct 28, 2010 | Honda Electrical Supplies
I have a coleman 5000 that won't hold voltage at 110 volts under load. It fluctuates up and down. The motor is running steady. What could be the cause of this?
govenor problem maybe does the engine sound slower when a load is on.
you will need something to read the power frequency
3000 rpm produces 50hz uk
3600 rpm produces 60hz
so if you have a meter to measure frequency you will also know what speed the engine is running at
Feb 27, 2010 | Coleman Powermate Powermate 5000W...
Generator was running and quit delivering voltage while running. Turned it off and then restarted and checked voltage with no load. no smell...plenty of oil...seems like a breaker8000 exl...#...
It very well may have been a breaker that opened up permanently.
But, I bet that the generator was under heavy load for prolonged time, and one / both of the diodes in voltage regulator have opened up. You will have to disassemble the end housing of the alternator to get to these, and then test with multimeter to know for sure.
Of course, your generator may have an electronic controller, and not use diodes / capacitor at all. Since don't have model #, can't be sure.
If engine has dropped much under 1800 (4 pole alternator) or 3600 (2 pole alternator) RPMs, then alternator output would tank or be nonexistent.
Dec 09, 2009 | Generac Electrical Supplies
Honda generator runs great,voltage output is good but when load is applied motor cuts off. no breakers tripped or resets tripped?
check your load..the generator is carrying heavy weight when you are going to load a high wattage thats why its RPM will turn slowly and have the possiblity to stop it...It MUST be needed the the given wattage of the generator is greater than the load you apply.for example:when your generator's specification is 3500 watts,tehn the load you are going to apply is i watts to 3499 watts only..
Nov 03, 2009 | Computers & Internet
RPM/voltage fluctuation on Guardian Primepact 50G
go to - look in their Service manuals section - good luck!!
May 28, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Voltage output is only 50 volts instead of 120 volts
If you need troubleshooting help for your Honda or other portable generator there's nothing better than a handy schematic. This detailed diagram will help you troubleshoot your portable generator. In publications or online you may find a variety of schematics for Honda or other portable generators.
One handy book, which can be ordered online and delivered straight to your home offers troubleshooting guidance, including a number of schematics, for Honda, ATI, Coleman, Generic, John Deere, Mitsubishi, North Star, Porter Cable and Robin Subaru portable generators.
The book, entitled, Small AC Generator Repair and Service Manual - 1st Edition Volume 2, is discounted for under $30 on one Web site.
This portable generator troubleshooting publication is 420 pages, replete with schematics in the former of illustrations and diagrams.
Jan 25, 2009 | Honda 3000 Watt Portable Generator
Coleman Powermate Premium Plus 6250W Portable Generator Logo
290 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
