Question about GE WBSE2090A Top Load Washer
Bleaching subsequent loads
I have a bleaching problem. When I run a load of whites with bleach in the bleach receptacle, later loads of colors get bleach spots! Any thoughts on what is going on here? Thanks!
I'm no repairman but here's a coupla thots:
1 - try running an empty load after bleaching. Save money and just use cold water. First add a few cups of water to the bleach dispenser to help flush out the old bleach that might remain, then run it.
2 - lemon juice is naturally acidic and should neutralize the bleach. You could add some to the bleach dispenser and do the above. Maybe mix a half-cup with a few cups of water and put in the dispenser, then run it. (Lemon juice [or vinegar] is good thing if you get bleach on your hands, too.)
OF COURSE -- Test to see if this works with a couple colored rags before running any good clothes through.
3 - How about using oxygen bleach alternatives (color-safe bleach) instead of regular bleach?
I suppose there could be a problem with your dispenser, idk....
Posted on Feb 20, 2009
Water does not go into the detergent chamber. The water comes out from under the machine on the floor.
Are you sure that is not the "bleach chamber"?
To avoid risk of "bleaching" some parts of clothes with concentrated, bleach, the washer will get the bleach only when water is full & washing has started.
Non-bleaching detergent can just be put in with dry clothes.
Dec 21, 2013 | Kenmore HE2 Plus Front Load Washer
Washing machine bleaching colored clothes by mistake
thanks for the question its possible that the bleach disp is clogged and when its suppose to release the bleach some stays hehind and theres still some left over from the last load i would check that thanks the appliance doc
Sep 16, 2008 | Washing Machines
Is there a difference between whitening and bleaching teeth?
According to the FDA, whitening makes teeth be natural tooth color and bleaching whitens beyond the natural color
Apr 24, 2013 | Health & Beauty
I just viewed a bunch of complaints about chlorine bleach getting dumped on the subsequent load, but did not see a true root cause response. 1st question: When you use chlorine bleach with the whitest...
chlorine bleach is a highly corrosive addition to laundry that is not necessary... try Borax and Hot water. If the clothes sat in the Bleach for the entire wash cycle it would damage them and shorten the life of the clothing fibers considerably...
Apr 21, 2017 | Whirlpool GHW9400 Front Load Washer
My front load washer will not dispense bleach or fabric softner.
We have the very same problem. Extremely frustrating, will not dispense bleach for the load intended, then it releases bleach for a load - causing bleaching on colored fabrics.
Sep 17, 2010 | LG WM2277H Front Load Washer
Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bleach ruins colored load done after white load
Your bleach dispenser is the problem. It needs to be replaced. All of the bleach isn't leaving the dispenser so when you go to wash your colored clothing what's left in there comes out. Best thing to do till you fix it is wash your whites last. You can try running some white vinegar through the wash on the hottest cycle. Pour the vinegar into the bleach area and the soap area and run it on hot. Run it a couple of times. If there is anything clogging up the dispenser this might clean it out. Let me know if you have any other questions and good luck.
Oct 18, 2008 | Whirlpool GHW9300 Duet Washer
Clothes picking up residual dyes & bleach spots
I dont think the washing machine is designed to put bleach in??
Remember a washing machine is never really empty of water.
It holds about 1 litre of water in the tub after each cycle.
Thats the way they are designed.
The same as front loader.
I would put clothing in the tub to bleach,then rinse them in the tub with cold water ,then wash them?? cheers
Jul 25, 2008 | Fisher Paykel EcoSmart GWL15
Hello sa-kap,
yYu said,
Hi, I have a top loading Kenmore Elite washer (don't know model #) from the year 2002. It has the automatic bleach dispenser. The problem is that if someone has washed clothes with bleach sometime during the day and someone else comes along and washes dark clothes, the clothes get ruined with dot bleach stains. It appears that the bleach remains in the washer. Any tips or do I need to buy a new washer? Any help would be greatly appreciated. Thank you
V.C.My problem is similar to that which VCasabona is having. Not just dots occur but often big splotches. It may not even be just a colored load following whites on the same day but, on occasion, it occurs on the next laundry day, a week later with the first load that is not the whites with bleach. Also, my wife adds the bleach to the filled washer (old school, I guess), rather than pouring into the dispenser. My water pressure, which is not at issue, is not what I need to address to remedy the situation. I have noted that the ledge that is part of the floating tub had some build-up of deposits, some of which may have been bleach. These I've reached in with damp cloths and removed as best I can. I've run full, empty loads through hoping this would flush out any lingering bleach. Because the occurrences run intermittently from infrequently to frequently I cannot be sure if any of my attempts to remedy the problem are having any effect. I've guessed at the model # of the Kenmore top load washer we own since Dec of 1999
Sounds like some water is remaining in the tub after the pump gets done emptying the washer.
So its the pump!
The Kenmore Elite is a good washer and I believe worth fixing!
Unless the cost is half the price of the cost of a replacement.
Bless You,
Please write me a good rating before you sign off.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
You might want to check with the company on this one. You can email them at their web site. We've never run into this and I haven't heard of anyone else who has. Maybe your unit isn't pumping properly or maybe some of the water is siphoning back into the tub? I have heard about pumps becoming partially or fully clogged and in need of being cleaned out.
Keep us posted on this one?
Jan 07, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
GE WBSE2090A Top Load Washer Logo
506 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
