Question about Acer TravelMate 2300 Notebook
My Combo Drive is not visible
Combo drive is not visible in my laptop.I don't know what's the problem?..I can open it and close t.but i can't access it.even image drive is not visible when i enabled that.can anyone give me the solution?
    Sergeant:
    Novelist:
  • 190 Answers
Please read to the end before atempting this.
Is this XP or Vista. In Windows based computers some times the High and Low filters get messed up in the registry. If the drive is still good and you had not had any issues with it not reading disks then the filter settings may be your problem. Try this:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
Note: Vista doesnt come with the run command as a choice so just type REGEDIT in the search bar above Start..
3) Click on the plus signs (+) next to the following folders to open them.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
(looks like same file name for XP and Visat?)
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
5) If you see any of the above keys, right-click on each of them and choose Delete
6) Close the Registry Editor
7) Reboot your computer
8) Click Start
9) Open My Computer and check to see if your CD or DVD drive shows now.
Open the device manager for your version of Windows and make sure the Rom Drive is showing and that it is not showing an exclamation mark. If you still do not see the Rom drive then your drive may be defective. Note: you migh have to reinstall some of your CD or DVD playing/burning software. Hope this helps... Dale
Posted on Mar 01, 2009
Hi all.. I am new to computers. I purchased a new assembled computer. windows 7 is installed in that. due to some virus threat, it is once again re installed. It worked properly for some days... suddenly...
Right Click "my computer".
Select manage
go to storage->Disk management
You may find a drive with an unallocated drive letter.
Assign a drive letter that is not in use and it should be ok
Sep 04, 2013 | Computers & Internet
Had a seagate free agent given as a present but i have lost the manual and don't know how to operate it. how do I transfer files and how do I download them onto another PC ?
Hi vic_barnes,
You don't need the manual to operate the external hard drive , all you need to do is connect the drive via the USB cable and your computer should accept it , and then you would find a removable drive visible in your my computer option.
Then you can open this drive and copy your files to and from it.
Hope this helps ..:)
Sep 03, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
My laptop disc driver is unable to read disc contents. also when we on the laptop dvd drive is not visible on screen . only after restarting it is visible on the screen. Regards anbu
device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Click on Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps don
Mar 13, 2011 | Computers & Internet
Dear Sir, In my Laptop if i see properties of drives it shows free space of 5 GB out of 15 GB but as I open the drive there are no folders in it. If go to histroy then I can access these folders. I have...
well this might be because the folders are hidden and you can make them visible by opening the drive and at top u can see tools tab , click it , select folder option, a new window opens, now select view tab at top, and u can find advanced settings, in that u can see show hidden files and folders- select it, now click apply and ok button and close that window and try to open the drive again.
good luck.
Jan 05, 2010 | Dell Inspiron 1525 Notebook
I have a similar kind of problem...
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 16, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Toshiba A305-6825 laptop prolem (no visible CD/DVD Rom drive). In Device Manager: HL-DT-ST dvdram gsa-t40F ATA device error. Media test failure. There appears to be CD/DVD combo drive firmware...
You seem to be onto things (though your problem classification was generic instead of for your Toshiba model A305.) Install all the updated drivers for your laptop from the laptop's support site (Toshiba's, that is) so you can use your drive. Drives fail sometimes, and you could try sticking an old movie or something in there instead of nothing, but it is likely it is just the missing driver.
Jul 19, 2008 | Computers & Internet
My disk drive
Under the drawer is a little latching metal clip - you can use a small screwdriver to gently operate the latch, it is probably just stuck in the open position.
Mar 15, 2008 | Dell Inspiron 6400 Notebook
My CD RW/COMBO drive is not visible in My computer
Removing Drive in Device Manager
Remove the drive name from Device Manager:
Select the drive name.
Click the Uninstall or Remove button (in Windows XP this is the square button with a red X, ).
Click Yes or OK to remove the CD listing.
Do not restart the computer.
Close Device Manager .
If your computer has Windows XP, restart computer!
Dec 13, 2007 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Computers & Internet Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
