Loses use of flashplayer?
I have flashplayer 10 installed on my pc...after i run my ''cleaners'' i lose use of it...i have to actually go into control panel - unistall then reinstall for it to work again??? any suggestions?
  • 131 Answers
Hi:
I'm not sure what you are running for "cleaners", but it sounds like your programs are mis-interpreting the registry entries of flashplayer to be an unwanted program. Look in the program's settings for an area where you can allow exceptions, and include flash player in the list. The other thing you might try is not running a registry cleaner, as most of these programs cause more trouble than they do good. If you are using them to make your computer run faster and more reliable, regular disk cleanup and defragmenter use will do more for you than any registry cleaner
Posted on Feb 20, 2009
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
Losing power
losing power can be down to an air leak spray some carb cleaner over the air lines and manifold. depending on the type of cleaner it will do one of two things engine will speed up or it will cut out. that will mean you have a leak spray the engine when it is upto temp normal running. usually around 10 to 15 min. were ever it makes a change in engine that is were a problem is.
Jun 04, 2013 | 2000 Audi A4
Facebook games keep freezing and losing server
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira.
You should be in pretty good shape if you run and install all of these programs.
Jul 29, 2012 | Zynga Facebook Apps
Can you fix bingo blitz please?
Make sure to select ALL of the "threat categories" when you install or configure Avira...
Jul 28, 2012 | Acer Computers & Internet
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Megapixel 10x digital zoom f=3.85mm web cam i want its driver
10x Digital Zoom f=3.85mm Megapixel webcam esenses
Apr 14, 2011 | Computers & Internet
I cannot download adobe flashplayer. Whenever I go to certain sites, I keep getting told that I need to disable Java or I have an older version of Adobe. I keep trying to download FP, but it keeps failing....
I had this problem before..you need to clean the registry files stored in your computers harddrive. The problem you are having now is that the flashplayer will not complete the download because the old flashplayer is priority even though you have upgraded your browser. I spent a few days when this happened to me. Try this free registry cleaner from CNET, click on the link and download it. After you download it, install it and run the program and it will clean all of your old files out of the harddrive. It will find and delete the old versions of Adobe. After you do that, resart the computer and redownload Adobe flash player.
http://download.cnet.com/Abexo-Free-Registry-Cleaner/3000-2094_4-10434886.html
Oct 18, 2009 | Microsoft Internet Explorer 8
Lose vacuum on pool bottom cleaner
My pool filter runs fine when skimming, but when I attach the droid or manual vacuum the basket has sucked air. Do impellers ware out? Is there a seal between the motor and the impeller that can leak air?
Jul 17, 2009 | Hayward SAND FILTER, PRO SERIES
Dell mini forced shut down, now runs slowly
go to start - accessories - system tools - system restore - choose a date when it was working fine, preferably the earliest date. then wait for it to shut down and restart. you will not lose any saved files or folders, you will only lose programs installed after the date you choose.
Jun 18, 2009 | Dell Inspiron Mini 10 Notebook
Computers & Internet Logo
David Payne
David Payne
