Question about Dell Dimension 8400 PC Desktop
EVGA 9400 GTvideo card problem only 1x mode
I bought a EVGA 9400 GT 1 GB video card. I have installed the updated drivers as well as the Control Panel software. When I start my computer I receive an alert "PCi Express card is in 1x mode. Press F2 to go to set up or F1 to continue". I go to set up But I donot know what I'm supposed to do. The 9400 GT was resommended by Dell saying it's compatible with my 8400. I get video to work but some of the videos the sound is off by a scond or two. Any suggestions would be greatly appreciated.
  • 1 more comment
  • Robert Castillo Feb 20, 2009
    I have a Pentium 4 3.40 GHz processor and the box says 300 watt minimum I believe i have a 350 watt power supply.It also requires minimum of 18 amps on the +12 volt rail. Could the amp requirement be the issue?
    I just replaced 2 GB of PC3200 with Kingston 2GB PC5300. I purchased the card and the memory together.
    If this helps I also forgot to mention I was replacing the ATI Radeon x1600 video card that I bought almost 3 years ago. I removed all the drivers and ATI software before I installed the 9400 GT.
    President:
  • 1,902 Answers
Sounds like the processor is not enough GHz to run the video card. If I am not mistaken the 9400 GT needs a 2.3GHz or higher processor and needs a 400 watt powersupply to run properly so if your computer is not set up to those specs the card will not work properly
Posted on Feb 20, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 20, 2009
    Yes that was going to be my next fix. This computer that you have is a great computer. But Dell does not always know what is right or if you have changed anything. How much memory do you have in your computer? If you are under 2 GBs then I would upgrade your memory also. This will help take a load off of your computer itself
  • Jeremy Reddick
    Then upgrade your power supply to get the proper amps and everything should work fine. You are having a Amp problem
Theres no sounds everytime im using media player
1) Go to: Start > Settings > Control Panel > Sounds, Speech, and Audio Devices > Audio tab 2) Check what's under "Sound playback: Default device" and "Sound recording: Default device". It these fields are grey and non-clickable, then most probably the audio card driver is missing or less probably the audio card itself is broken. 3A) If you have an original CD of your computer, motherboard, or audio card, insert the CD and install the driver from it. 3B) Or alternatively insert the CD and go to: Start > Settings > Control Panel > Performance and Maintenance > System > Hardware > Device Manager, find any unidentified device in the list, or expand the "Sound, video and game controllers" branch, identify the Audio card > Right click > Update driver... > Install the software automatically > Next 3C) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers. P.S. These steps mentioned above are for Windows XP, but will be quite similar on other Windows versions, too.
Mar 06, 2011 | Computers & Internet
Sound and audio devices
New install window but is not available sound in my ibm laptop
2) Check what's under "Sound playback: Default device". If these fields are grey and non-clickable, then most probably the audio card driver is missing or less probably the audio card itself is broken.
Mar 05, 2011 | IBM Computers & Internet
Can't hear and can't use the mike. Drivers may be missing
Go to the manufacturer's website for that particular computer and download the audio drivers needed for the microphone.
Mar 05, 2011 | Computers & Internet
I m using geforce 9400 gt chipset card from zotac. when ver i try to update my driver to a newer version system color scheme will go down to 4bit and it will refuse to change. its working fine with the old...
Hello dimash, you must remove nvidia old drivers before installing latest driver, go to Start> Control Panel > Uninstall a program > Nvidia Drivers Remove, Restart Computer, i found newest drivers for you video card, which operating system did you install on? To Change Resolution Go to Nvidia Control Panel > Display > Change Resolution > Color depth : Highest (32-bit)
Click save driver to your computer, install the driver, don't forget to restart the computer. Here is the links.
Copy and paste link into your browser and press enter.
For Windows XP Professional, Home Edition
1. http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/260.99/260.99_desktop_winxp_32bit_english_whql.exe&lang=us&type=GeForce
For Windows 7, Vista 32-Bit=x86
2. http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/260.99/260.99_desktop_win7_winvista_32bit_english_whql.exe&lang=us&type=GeForce
For Windows 7, Vista 64-Bit=x64
http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/260.99/260.99_desktop_win7_winvista_64bit_english_whql.exe&lang=us&type=GeForce
Good Luck!
Dec 02, 2010 | Jaton NVIDIA GeForce 9400 GT, PCI Express...
Hi can i install evga gforce 9500 gt video card
Yes, it will work just fine. Just make sure you uninstall the drivers of the embedded one before installing the new one and you disable it from the BIOS immediately after.
Apr 18, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Graphic card stopped working normally
Uninstall the current display drivers from the Control Panel > Remove Programs.
Then, go to Windows Update to download their version of the driver. It will work.
Aug 06, 2009 | Pine Technology XFX GeForce 9400 GT, PCI...
Dell Dimension 8400 PC Desktop Logo
159 people viewed this question
Alun Cox
