Question about Lexmark X5150 All-In-One InkJet Printer
Hello, pls i need to know the right catridges for my lexmark all-in-one printer, thanks.
    President:
  • 2,110 Answers
Lexmark X5150 uses the 18L0032 and 18L0042 inkjet cartridges.
here u can purchase
http://www.databazaar.com/Inkjet_Cartridge/Catalog/X5150_6352.html
Posted on Feb 20, 2009
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Lexmark z1420 the on/off button keeps flashing and it will not print anything
hi this is kamal,
pls it may be because of dust so pls put off your catridge from printer and then again install it and pls uninstall driver and install it again...
regards
kamal singh
Oct 08, 2009 | Lexmark Z1420 Printer
Hardware error 0502, how do I fix this? What causes it?
It happpens when the Catridge is unable to Communicate with the Printer............. In this case what i would request you to do is............... Unplug the Power Supply from the Printer When u remove the cover of the Printer behing the Catridge carrier which holds the catridges u will see a thin long transparent strip which looks like a Tap........... Take a Dry Paper Towel and Gently wipe that tape from right to the left it is very delicate so pls do it gently............ Now Take out both the Catridges from the Printer.............. Move the Catridge carrier which holds the catridge, From right to the Left and From Left to Right for abt 10 Times............... Now u can insert both the catridges in and Turn On the Machine.......... Good Luck
Jan 31, 2009 | Lexmark X6170 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have a SAMSUNG printer Model MultiJet 4500c.Please advis what color catridge or what number of lexmark I can use for this printer. Chaoho Meng
Hello there,
This printer can use the Lexmark color cartridge # 12A1980.
The black, FYI, is #12A1970.
Thanks,
Lolita
Apr 10, 2008 | Office Equipment & Supplies
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
