Question about Intel D845GVSR Motherboard
Mic socket is not working
Hello
From many days i am having these problem with my system my mic socket is not working properly and when I adjust it, it will work but know it is totally dead I can hear the speaker voice but my mic socket is taking my voice I had replace the ear phone set new but the same problem it is showing I have Intel D845GVSR mother board can I replace the audio mic pin sockets are what else I should have to do Please advice me as soon as possible
  • 530 Answers
Hi im josh in cebu phils. may i help you? friend if the problem is your mic socket is not working. try buy a new sound card then put it in the pci slot. it will give you new sockets for audio, mic.etc.at the same time it will give you better audio performance. good luck.
Posted on Feb 21, 2009
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Hello i have a toshiba l305 laptop and can't get the internal mic to work with any program that uses it
The Microphone might not be working, as it may not be enabled.
However, you may enable the Microphone manually by performing the below steps:
For Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. 4) Click the OK button. 5) Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
For Windows Vista:
1) Right click Speaker near Clock - Recording Devices - right click in box - check 2) Show Disconnected Devices and Show Disabled Devices - check your mic - highlight them and then on lower right properties. 3) Make sure the proper one is enabled and check other settings - on Levels tab make sure MUTE is unchecked and APPLY / OK changes.
For Windows 7:
1) Right click on the volume icon in the system tray and then click “Recording devices”. 2) Right click on the blank place in the popped up window and then select “Show Disabled Devices” and “Show Disconnected Devices”. 3) Right click on Microphone and then click “Enable”. 4) Highlight the microphone and then choose “Set as Default Device”. 5) Click Apply. 6) Select Microphone and click on Properties. 7) Click on Levels tab. The default Microphone Boost is set to 0, increase it.
Hope this helps.
Jun 23, 2010 | Computers & Internet
WHERE DO I CONNECT MIC
If you have a front panel, the sockets are usually marked. The Mic socket should have a symbol representing an old fashioned desktop microphone. Perhaps the easiest to recognise is the headphone socket.
Line out will, usually, work fine from the headphone socket but, depending on what you want it for, may need some amplification. Similarly, line in will usually be happy in the Mic socket.
If there are no markings, trial and error will not do any damage. Start with the line out which will not be powered and play some Windows(R) sounds.
CJ
Jul 02, 2010 | Intel D915GAV Motherboard
Microphone doesn't work on Gigayte GA-8I915P
Right click on volume properties(on task bar) and select volume properties, check whether the Voice recording with proper device selected.
Dec 08, 2009 | Gigabyte GA-8I915P Duo Pro Motherboard
Shure mic with a jack on gigabyte motherboard
Test your microphone if it properly working. Go to Sounds and Audio Devices properties and then go to Voice Tab and then Test Hardware. If the computer does'nt hear anything then your mic is faulty.
Nov 08, 2009 | Intel Motherboard
My laptop microphone isnt working
Good day, Hi, to test your laptop mic, open the sound recorder. 1. if you ar using XP, goto START, All Programs, Accessories, Entertaiment, Sound Recorder. If the sound recorder loads normally, press the red button, shout as load as you can, you will see sound waves on the recorder. 2. If the sound recorder does not loads, chances are your mic isn't working properly, Load the device Driver for your mic, you can find the driver on the CD that came with your laptop, if not you may need to go to the Internet to find the MIC driver. 3. If the driver is loaded on your laptop, chances are it may be defective, you have 2 options, 1. replace the mic on your laptop, which requires you to dismantel it, get the defective mic and replace it. 2. just get an external mic. hope this may help.
Aug 02, 2009 | Computers & Internet
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
Mic not working with system
try to change your system just like the one that youve said that its working. it is maybe the system got the problem. or try this one, go to control panel see if your mic is working on your audio software application. set it to make it work by configuring like the volume or anything. hope that helps!
CHARCOIS
Aug 09, 2008 | Intel D845GVSR Motherboard
Intel D845GVSR Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
