Question about HP Pavilion ze4300 Notebook
My laptop does not turn on
I brough my laptop to local compuetr rapir shop becuase ac/dc jack problems, and later I got a phone call and they said "we replaced de jack but is not really your jack is *********** board" and now it does turn on. you need tu replaced a mother board.
It was only the jack losing conection. How come become a mother board problem??
Do yuo have any advise por this problem???
Thank you!!!!
    President:
  • 1,902 Answers
No idea why they fixed the problem then said it is the motherboard. There are times though when the motherboard is actually bad and it does need to be replaced even with replacing the jack. With a motherboard it has to convernt electricity and sometimes the wiring is fried or bad. But if it works then let it run, if not, I would take it some where else and have another company check to make sure that they did not melt the board causing it to be a board problem
Posted on Feb 20, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 20, 2009
The power light is off The charger is OK with 19Volt The connector is OK and somehow there is a problem with in the power
remove the battery, connect the ac adapter and turn on the laptop. If it turns on then it's your battery. If it doesn't turn on then it is either your ac adapter, your dc jack, or your system board.
If it doesn't turn on then try a different ac adapter from your local pc shop or electronics store. If it still doesn't work then try moving the ac adapter connector and see if it attempts to turn on. If it does then it's your dc jack. If it is your dc jack then you will have to replace it. The problem with that is that it can be pretty expensive to replace it.
The way I have solved this is by ordering a dc jack on ebay or any other online parts supplier and replacing it myself. If you can take your computer apart and put it back together then it's just a matter of desoldering and soldering the new one. If you want you can have a pc or tv shop do the soldering for you.
Have fun and let me know if you have anymore questions.
Dec 14, 2010 | IBM ThinkPad X60 Tablet PC
My gateway laptop note book, will not power up, I have checked the cord, battery etc. Went to turn it on one day and no power? someone mentioned that it over heated?
First of all, take the battery off and try to turn it on with the ac adapter (power cord) connected. If it comes up without the battery then it's your battery.
If it doesn't turn on without the battery and with just the ac adapter, try a different ac adapter. You can find one to try at your local pc shop or electronics store. If it comes up with another ac adapter then all you need to do is purchase an ac adapter at the store or order one online (cheaper).
If it still doesn't come on then it's either your dc jack or your motherboard. Normally if it's just the dc jack it will turn on or attempt to turn on when you wiggle the connecter in the ac adapter connection. If it's your dc jack it's relatively inexpensive to purchase online. The problem comes with having to take apart the laptop, desoldering the old and soldering the new dc jack, and putting the computer back together.
Good luck and let me know if you have any other questions.
Oct 23, 2010 | Computers & Internet
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
My laptop shut down on me and the problem is it will not turn on no more it will start up and then cut right back off my friend say it might b something wrong with the mother board
Do the following:
1. Disconnect the ac adapter.
2. Remove the battery.
3. Find the reset button and reset your laptop. It should be located on the bottom part of your computer and marked "reset". Take a tiny screwdriver, a thumbtack pin, a paper clip, or any similiar object and push on the reset pin.
4. Plug in your ac adapter (without the battery) and try it. If it works, go ahead and reinstall your battery and try it with the ac adapter on.
5. If it turns on with the ac adapter connected and the battery installed then you're good to go. If it doesn't then it's your battery.
6. If it does not turn on with your battery removed and the ac adapter connected then it's either the ac adapter or the dc jack.
7. You can test the ac adapter at your local pc shop or electronics store. You can purchase an ac adapter at one of these shops or order it online.
8. If it does not work with another ac adapter then it's more than likely your "dc jack" and that takes alot of work. The dc jack itself is relatively inexpensive ($6 to $30) depending on where you purchase it. The fun part comes in replacing it. You can do it yourself if you're good at soldering or you can get it done at your local pc shop or if you can take your laptop apart and put it back together then any local tv shop can do the soldering for you.
9. Have fun, Good luck, and let me know the outcome.
Oct 14, 2010 | Computers & Internet
My computer does not turn on when i press the power button my computer is plugged into wall outlet and the plug icon. the power icon and the battery icon r all green but the hard disk drive light is not...
Try this. Take the battery off and connect the ac adapter and try to turn it on. If it works then it's your battery. If it doesn't than it's either the ac adapter or your dc jack. Try an ac adapter from an electronics or pc shop. If it works your in good shape. If it doesn't then it might be your dc jack. The jack itself is really inexepnsive and you can get a local tv shop to solder it for you if you can't do it. It's also cheaper if you take the computer apart yourself and put it back together after the shop does their part. Good luck!
Sep 20, 2010 | Toshiba Computers & Internet
Notebook won't power on
Take the battery off and try to turn it on with just the power cord. If it works then it's your battery. If it doesn't then it's either your ac adapter or your dc jack. Try an ac adapter from a local pc shop or electronics shop. AC adapters run around 40 dollars or less if you order them online. DC jacks are a different story. I the jack needs to be replaced you'll have to take it to a pc shop or if you can do it yourself then order a dc jack online or purchase it online and take the computer apart replace the dc jack (you'll have to desolder the old one and solder the new one one). Good luck!
Aug 23, 2010 | HP Compaq nx8220 Notebook
Hi in my laptop charging shows that pluged in,not charging what can i do
Is the computer working at all? If it is then it's probably your battery. You can order one on ebay. If it is not working at all then try a known good ac adapter. If it works then replace your ac adapter. You can order it on ebay also. If it still does not work, then more than likely it is your dc jack. Order it, remove and replace it or have someone do it for you. A computer repair shop will do it. If you can take the laptop apart and put it back together then all you have to do is solder the new dc jack or have a local pc or tv shop do the soldering for you. Good Luck!
Aug 16, 2010 | Acer Computers & Internet
I charge my laptop and it shows plugged in but not charging..and charging doesnt last long..why?? and when its charging...it will till 91% and after that it wiil just say not charging....
Take your battery off and plug in the AC adapter, turn on your computer. If it works then you need to replace your battery. If it does not, then you need to replace your ac adapter or your dc jack. It's easy enough to test another ac adapter at your local pc shop. If it is the dc jack then it will involve replacing it. If you can solder then you can purchase one locally or order it on the internet and replace it yourself. If you can't solder then you need to have someone do it for you.
Aug 05, 2010 | Gateway Computers & Internet
No ac power but plugged in
If you plugged in the ac adapter, and you still get no power and cannot turn it on, the first thing to check is the AC adapter. Get a voltage meter, set it to 200 DC, put the positive on the inside and the ground on the outside. Unless you have a highpower alienware laptop, it should read +/- 20 V, most likely 19.xx. If your AC adapter is good, then the DC jack, what the adapter plugs into, is bad. In this case, the laptop will have to be disassembled, the mother boared removed, the old DC jack de-soldered and taken off, and a new DC jack soldered on. You would really need to take it to a qualified techninician at a shop to di it.
Mar 21, 2009 | Acer Aspire 5100-5022 Notebook
Gateway MX6920 won't power on.
You Need To Replace The DC Jack In The Laptop...
It Is The Jack THat Your AC Adapter Plugs into....
The Jack Needs to Be Unsoldered/Removed/Cleaned And A New Jack Installed..
I Wouldn't Bring It To That Same Repair Shop To Do THe DC Jack Repair FYI...... ouch!!!
http://www.ifixlaptops.com
Nov 16, 2008 | Gateway MX6920 Notebook
HP Pavilion ze4300 Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
