Question about Nintendo DS Lite Console
Battery my torch battery has just died where do i find a new one
  • 50 Answers
Wat do u mean torch battery?????????
Posted on Feb 20, 2009
How to put the batteries in super bright torch 14 led
You may have reversed the battery carrier when you installed it.
Nov 25, 2014 | Cars & Trucks
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
My bb torch keeps shutting down! It says battery drained shutting down. The battery is completely charged.
may be the battery's life is up. try replacing the battery.
before buying a new one, try changing with another battery to check if its a battery problem or phone problem
Jul 30, 2012 | RIM BlackBerry Torch Cell Phone
Aston martin rapide battery has died and cant open the doors
When the battery goes flat on a rapide the windows are up. The doors are frameless so the windows are located in the seals in the door aperture. You cannot open the doors and you cannot open the boot. Look through the front grille towards the radiator with a torch and you will see the bonnet release cable outer sheath. If you pull the outer sheath it will put enough tension on the cable to release the bonnet catch. With the bonnet open you can charge the battery. Negative clip on the alternator casing and positive clip on the central charging stud.
Mar 04, 2012 | Cars & Trucks
After fitting new battery on my fjr 1300 Drove a long journey stoped and it would not start as if the battery was dead. left it for a while and it started with loads of power in the battery any thoughts...
Have your charging system looked at, first do a simple multimeter test, get a multimeter, switch it on to Volts, start bike and see what it reads, put multimeter prongs directly on battery, very simple, if its below 12V you have a charging problem. If your battery is new and your charging system is faulty the bike will start and go, but when you switch it off the battery will be dead because it has not been charging. When you let a dead battery sit for a while it will charge itself a little, enough to start the bike up. Have you ever had a flat torch or mobile phone, it will die when battery is flat but when you try and switch them on again after a little while, they will work a little and die again, same with bikes, cars etc. All the best, Forever Two Wheels :)
Mar 28, 2011 | 2002 Yamaha FJR 1300
F-S1 battery life is too short
The Torch's battery life is notoriously short. I would suggest you purchase an extended battery for the phone.
There's a few different options available for you:
You may purchase an extended battery, but it requires a different backing.
Or you can purchase another battery and swap them out.
Extended:
http://www.buy.com/prod/black-for-blackberry-torch-9800-extended-battery-door/q/sellerid/24501607/loc/111/219781558.html
Another battery:
http://www.google.com/products/catalog?hl=en&q=oem+torch+battery&bav=on.2,or.r_gc.r_pw.&um=1&ie=UTF-8&cid=16050621926286596060&sa=X&ei=j8iKTcTKDIb2gAeUkMjKDQ&ved=0CCkQ8wIwAg#
Mar 24, 2011 | RIM Blackberry F-S1 Battery for Blackberry...
Fully charged Lithium batteries dies out too quick and the USB cable does not work? Please help. thank you.
If the lithium batteries are of the AA shape then put them in a small torch and leave the torch on to fully run them down. If they are of an odd shape endeavor to do this with bulb wire and tape. Then try recharging them. If this fails- simply get a new set of batteries at first. Then come back
Jun 01, 2007 | Konica Minolta DiMAGE X Digital Camera
Nintendo DS Lite Console Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
