Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
How much oil needed in crank case.
I need to know the ratio of gas/oil for my tiller.
4 Suggested Answers
  • 111 Answers
SOURCE: I have a tb20cs and I need to now the oil-gas
The fuel ratio is 40:1. You can get the TRUfuel that comes in a bottle and stays fresh for a very long period of time. You should be able to get the TRUfuel at Oreilly's Auto parts stores or from Wal-Mart.
Posted on Mar 31, 2011
  • 10865 Answers
SOURCE: what oil gas ratio do
Hello rvan. the ratio is 50:1. the easiest way to achieve this is to buy a 2 gallon plastic gas can and a few of the 2 cycle engine oil bottles that are made especially to add to either one or two gallons of gas. Joe
Posted on Aug 03, 2011
Knucklebstr
  • 222 Answers
SOURCE: I have a troy bilt
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Posted on Aug 12, 2011
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
After overfilling crank case with oil and fixing that issue. It is now very hard to pull through
remove the spark plug and pull the starter cord a few times. see if oil spits out when you do this. sounds like there is too much oil or maybe gas in the cylinder. let us know what you find after you do this.
Jul 10, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
May 30, 2011 | Mtd Garden Tiller (Mtd)
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
I need to find out gas to oil ratio on 6.5 hp craftsman lawn mowe
This info is available at any dealer or repair shop. I would recommend contacting them to be sure. The lead says mini-tiller but your question says lawn mower. The 6.5hp motors, as far as I've dealt with were 4 stroke which means no mixture, but check with a dealer or shop, they'll know.
Apr 21, 2010 | Craftsman Gas Mini - Tiller/Edger
What is the correct oil/gas mix ratio?
The 2 cycle needs oil and gas mixed while the 4 cycle needs the oil changed every 10 hours of use. 2 cycle is 28:1
Jul 03, 2009 | Mantis 2-Cycle Tiller
What's the gas/oil ratio for CT 16 tiller
Husqvarna says 50:1
Here is a link to the break down repair manual for future use
I will send a link to the user manual when located.
Please rate this fixya solution
May 13, 2009 | Husqvarna Garden
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
62 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
