Question about Canon Office Equipment & Supplies
Getting the ip address of a cannon imagerunner 3570 copier
I need instructions to get the IPaddress of an imagerunner 3570 copier
Thanks
    Problem Solver:
  • 6 Answers
First check your m/c having fiery ( Network Card )
then go to additional features function
you have to set ip address like 192.168.36.10
then configured with your pc
restart m/c
your pc in network connection click on view workgroup
you will see a new group
double click on it to install your pc
Posted on Mar 04, 2009
Where can i find the waste toner in on this machine cannon ir 3570 copier
The waste toner is located on the front of the machine. You first want to lower the cover that allows you to insert the toner, then locate two rather large, silver screws that connect that front cover assembly to the copier. After removing the two screws, the toner bottle will be exposed.
If you need any further assistance, please let me know.
David R.
Dec 10, 2010 | Canon imageRUNNER 3570 Copier
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
Dec 16, 2009 | Canon imageRunner C3100 Copier
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
How to change the port number of canon imagerunner 3570 for scan n email
On the control panel select additional functions- system settings- network settings, then scroll down for e-mail settings. The port can be changed there. You can also type the IP address of the copier in internet explorer, and change it though that interface.
Jul 15, 2009 | Canon imageRUNNER 2220i Grayscale Copier
How to find IP address
Print the config page, is the easiest way -Carl
Jun 23, 2009 | Canon imageRUNNER 1023iF Black and White...
How to i configure the ip address in cannon ir400
configure your printer ip address 192.168.1.1and then configure your pc ip address 192.168.1.30
then ping 192.168.1.1 on run command. if no error is display then your printer is configure with PC.
if any problem call me after 7pm
Jun 05, 2009 | Canon imageRUNNER 400S Copier
I have a cannon imagerunner 3570 when i print the paper gets jamm
try with another driver like pcl 6.41 and use lan cable
Feb 17, 2009 | Canon imageRUNNER 5000 Copier
Faxing with the Canon 3570 Image Runner
On the copier display screen is their a tab that says "send"? If not then you do not have the fax option installed. If you have the machine on your network, find out the IP address assigned to the machine and enter the IP address in the address bar of your Internet Explorer browser to access the machine settings from your PC. If you have a fax option you should be able to set it up from there.
Printdoctor
Dec 17, 2008 | Canon imageRUNNER 3570 Copier
Won't PDF to email
I had the same issue when migrating between exchange servers. basically the scanner settings were pointing to the old exchange servers IP. I set that to the new IP and it resolved the issue.
Dec 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
452 people viewed this question
old marine
old marine
