Question about Bosch Electrical Supplies
I have a bosch impact drillgsb20-2 re
The problem is it only rotates when you rattle it about or slightly touch the reverse or forwrd mode switch,its like something is just not biting,im a joiner not an electrician any ideas
  • 169 Answers
The wires that go to the switches are usually attached using a spade lug that can get loose over time. Take the drill apart carefully, gently tug on the wires one at a time, and pinch the "female" part of any that seem loose to you.
Regards,
Carl
Posted on Feb 23, 2009
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
The wrench is making a rattling when operated and if you put slight pressure on the shaft the rattling goes. If you could help it would be a great help thank Kev
pos 14 pos 15 and pos 20 control it and replace if you see worn parts all together but if it is still making noise and it has its working hours on it replace also pos 26 . (control also the ballbearings on tolerance and its flexible
Makita 6906 Impact Wrench Parts
Sep 06, 2011 | Makita 6906 9 Amp 34Inch Impact Wrench
My sons gator will only got in reverse it wont go in forwrd
Pull the shifter switch out and verify that the connectors under neath are connected
Aug 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
Have a problem with Hitachi WR22SA Impact Wrench Rotates in the forward (on) direction but not in reverse (off) Can you tell me what is the likely problem?
Please try to locate the forward/reverse push button switch. Please try also referring to your users guide. Forward/reverse has a different or separate switch. Thanks for asking.
Jun 14, 2011 | Hitachi WR22SA 3/4" Electric Impact Wrench
Panasonic EY7540 impact driver. Does not go into reverse on 1st
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
Sep 26, 2009 | Panasonic Cordless 12V Compact Impact...
Bosch 1199vsr stopped working while drilling through concrete. The reverse works. Help
your tool should have a rotating reversing switch and the contacts for the forward rotation might be dirty or burnt. I would unplug the tool and remove the screw holding the back handle half on and look to see if anything is burnt or just dirty or bent. If you have an air compressor try blowing thru all areas of the tool. Let me know if this doesn't work you can also go to Boschtools.com and type in your model number on the left hand side after clicking on manuals.
Jun 28, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I have a bosch rotary hammer 11245evs and it was working when i put it away in its case, now it will not hammer. Drills ok. larry
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Apr 16, 2009 | Bosch 11241EVS SDS-Max Rotary Hammer
No reverse after rebuild on 4L60E Transmission from 1995 GMC Sono
There isn't a modulator on this trans as it is electronic
You can have first gear going forwrd but no reverse. It is possible. The low/ reverse clutch isn't needed to go forward.
Jan 19, 2009 | 1995 GMC Sonoma
Electrical Supplies Logo
83 people viewed this question
Top Bosch Electrical Supplies Experts
wadingriver
wadingriver
Steven Brandon
Steven Brandon
protojexxx
Are you a Bosch Electrical Supply Expert? Answer questions, earn points and help others
