Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
How much oil needed in crank case
Where should it be on the filler cap - instruction book missing and
don't know the ratio of gas/oil
  • Nicolas
    Nicolas May 11, 2010
    Hey!
    Is your model an TB425CS?
    Nic
2 Suggested Answers
Knucklebstr
  • 222 Answers
SOURCE: I have a troy bilt
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Posted on Aug 12, 2011
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Code P0455
Ford error code P0455
- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
The P0455 it's a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
http://engine-codes.com/p0455_ford.html
http://www.stangnet.com/images/stories/docs/sn95_TSBs/03-20-03.pdf
Sep 08, 2014 | 1998 Ford Ranger
What kind oil is i fill in fuel tank
First you must know the proper fuel to oil ratio. I have seen saws run 50:1, 40:1, and 32:1. When you buy some 2 cycle oil there will be instructions on the container on how much oil you need to add per gallon of gas to get the ratio you saw needs. On some saws the ratio is listed on the fuel cap.
Aug 31, 2013 | Garden
Went through automatic carwash with gas cap off and gas cap door open
should have flap door where you put gas nozzle into filler tube to fill up gas tank.if flap door not missing not too much got in gas tank.add more gas and gas treatment to remove water if you have stalling problems drain fuel tank.change fuel filter.
Nov 17, 2012 | 2005 Lexus Ls 430
Code 0455 on a 2004 grand prix
P0455 - Evaporative Emission Control (fuel vapor control) System Leak Detected Gross Leak
Possible causes- Missing or loose fuel cap
- Fuel tank leaking Tech notes The P0455 it's a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
Oct 02, 2012 | 2004 Pontiac Grand Prix
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have no gears forward or reverse. My Vehicle is a 2003 Dodge Ram 1500 4x4 Hemi with 170,000 on the clock. Fluid is clean and full with no leaks. I have the following trouble codes:...
Your scanner will give you the code but it will not tell you how to fix your vehicle. Scanners basically tell you what systems to check or what systems are failing.
These are what your codes mean:
P0700: Transmission Control Module
- Shorted or open circuit within transmission control module (TCM)
- Failure of transaxle control module. This is just a informative code.
P0734: Gear ratio error in 4th gear
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
P0732: Gear ratio error in 2nd gear
- Shift solenoids
P0731: Gear ratio error in 1st gear
- Shift solenoids
P0871: Transmission Fluid Pressure Sensor Switch C
P0876: Transmission Fluid Pressure Sensor Switch D
Emissions Codes:
P0400: Exhaust Gas Recirculation Flow Malfunction
- Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- EGR volume control solenoid valve
- Dead (Weak) battery
- EGR temperature sensor and circuit
- EGR Valve
How to fix :
- Clean EGR Valve
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
P0440: EVAP Emission Control System Malfunction
- Missing Fuel cap
- Incorrect fuel tank vacuum relief valve
How to fix:
- Retight or replaced fuel tank filler cap
- Replaced damage or leaking EVAP canister
P0456: EVAP Control System Leak Detected (Very Small Leak)
- Missing Fuel cap
How to fix:
P0441: EVAP Emission Control System Incorrect Purge
- Missing Fuel cap
How to fix:
Based on the info check your EVAP system. I would check for leaks and maybe replace the EGR and the canister.
For the transmission check the TCM also you may need to take it to a mechanic though.
Hope this helps a little.
- Tech 101 (ASE CERTIFIED MASTER TECHNICIAN)
- Larson's Mobile Auto Repair
- 209-845-7620
- Oakdale, CA
Dec 31, 2010 | Dodge Pickup Cars & Trucks
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
Nov 24, 2008 | Homelite Consumer Products MightyLite...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
162 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
