Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Refrigerator won't shut off
First it would freeze up then defrost everything , we found that we had 25 ft of extra tubeing for the water coiled up behind the draws on the bottom of refrig, this would be frozen solid which would cause the defrostor to come on. So we uncoiled it and pulled it to the outside of the refrigerator. we now have it set next to defrost and it won't shut off everything is freezing again
    Novelist:
  • 117 Answers
First of all, please recoil the tubing and put it back. exactly where it was. If you do not, when we figure out the real reason for your unit to keep running and make the repair, you will not have any cold water at your fountain dispenser. That chills the water so when you want a glass of cold water, it supplies the cold water that is laying in the tubing first. Next, set both adjustment controls to their middle settings and then in the fresh food section, al the way at the rear of the ceiling, you will see louvered vents. I want you to use duct tape and cover 2/3 of the vents and wait 24 hours for everything to stablize. After this period of time, let me know how things are now and I will instruct further, if needed.
Waiting to hear from you,
Eric Campion
Posted on Feb 20, 2009
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
This is the second time the freezer accumulates water and freezers at the bottom of the freezer section of the Admiral HMG67158, 26.6 cu ft freez/refrig. The coils behind the panel were completely frozen...
unplug unit, remove back panel inside freezer and manually defrost with hair dryer, sounds like you have a defrost problem, check defrost thermostat, defrost heater or defrost timer, defrosting with hair dryer will fix until it freezes up again
Sep 30, 2010 | Admiral Refrigerators
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The drain at the center-base of the freezer freezes shut with ice. Water accumulates on the frig shelves and under the veg bins. Why and what to do? Frig is a Whirlpool 21 cu-ft ET1CHMXKB03 built in 2004.
There is supposed to be a defrost element that goes through the first part of the drain, it may have been pulled out or it may be malfunctioning. After the evaporator defrost cycle the water should drain through the drain tube, since it's frozen up the water just accumulates in the fridge. If you take off the inside panel that covers the evaporator coils (the coils that freeze up) you should be able to see the evaporator defrost element and the drain defrost element. Inspect the drain defrost element to see if it's in the drain tube like it should be or if it needs to be replaced.
Mar 26, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Freezer runs at 20 below and refrigerator runs at 60 ge profile
Most likely the defrost heater is burned out below the evaporator coil. It will be easy to spot because on the profile the defrost heater has a glass tube covering the element inside. You will need to defrost first before you will be able to see anything. If you replace the defrost heater also replace the defrost thermostat, Thanks, Sea breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
ICE MAKER NOT GETTING WATER FOR ICE BUT THE DOOR UNIT WORKS
I had this problem and eventually traced it to the water freezing in the fill tube in the freezer.  I defrosted the tube and no more problem
Jan 18, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Kenmore 71192100 frost free keeps freezing up
Hi. thanks for the question . The first thing i would do is clear the drain tube .that could be why the freezer ices up .too much moisture Clean the drain, And the coils at the back. thanks the appliance doc
Sep 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer coils and water in drain tube frozen
check to see if the fan running first, if yes than you may be losing freon. if not , try a new fan motor
Jul 29, 2008 | GE GTH18KBM Top Freezer Refrigerator
Water dripping from freezer
a quick fix I found is to hang a peice of copper wire from the defroster bar in the freezer and let it hang into the drain tube when the defroster bar gets hot it heats the copper to prevent the freezing,but the thing you should do is check the resistance with an ohm meter across the defroster bar,if its ok its the defroster assembly located in the fridge
Jun 03, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
174 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
