Question about Kodak EasyShare C310 Digital Camera
If you put in fully charged battery and after taking one picture it reads battery low whats the problem
    Scholar:
  • 165 Answers
Two problems either of that will be causing this. 1)either the battery is drained internally its showing up charged on the device but actually not getting charged so its happening. to resolve this replace the battery. 2)either the connector which is touching the battery internally is got loose internally so its showing up this problem. to resolve that connector problem the device must be opened and that connector should be resoldered.its a metal connector.
Posted on Feb 20, 2009
Battery
have you tried using other brand of batteries ?
if you use rechargeable batteries, try them fully charged at another device and see if they last that long. if they last more than in the camera, then your camera might have an electric issue
Jun 23, 2013 | Kodak EASYSHARE Z1485 IS Digital Camera
My Sansa fuse will not start, or charge
This sounds like a bad alternator.Remove the battery and have it charged and tested, if the battery is fully charged then truck should start and run for a while.With a bad alternator the battery light will come on and truck will run until battery life is discharged.With the battery fully charged and truck running put a tester on the battery to test the alternator output. the reading should be 13.5 - 14.7volts. any reading below 13.0 replace the alternator.
Do not drive truck to far as when the battery voltage gets low truck will die out.
Apr 01, 2012 | Cars & Trucks
When I try to take a picture it say battery depleted....what is the meaning of that
this usually means that the battery needs to be replaced or recharged. if the battery if fully charged it maybe that the rating of the battery is too low and the internal system decides that the battery power level even when fully charged is not enough for the taking of pictures.
try and battery with a higher ah rating. if the battery is a vendor specific block battery and not the usual. off the shelf aa and aaa type etc then speak to your dealer about the problem or a replacement battery. it would be useful to know the model of the camera in question.
i hope this was helpful
Dec 12, 2010 | Cameras
I have a low battery indication with a fully charged battery on a Sony DSC-F717. What do I do?
First, even a fully charged battery may not be working right - VERY common.
Does the camera do this on two batteries, one old and one much newer? (I say this because lithium batteries are good for about 500 charges - if you are over this, the batteries will always read weak...)
A service shop can test the camera and see if the battery is reading correctly. A service shop may allow you to try the SHOP's good battery in your camera and see if it reads right. If OK, you need a new battery.
The service shop can reload the operating data into your camera - I have fixed them this way myself.
If not, the circuit board that handles charging and batteries may run you $275 plus labour. (The board is not repairable)
Mar 22, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
What should be the percentage of the battery when its fully charged on an aprilia 125 rs
If the system is 12 volt, which I think it is, a new battery should read 13+ volts fully charged. Note! You can have 12 volts, but low amps. You need to ideally charge the battery and put a load tester on it to know the truth about the condition of the battery. Chaz Moto DC
Jan 22, 2010 | 2006 Aprilia RS 125
Battery problem?
i have this excact same camera ... happened to me... it will work after a little bit, open battery door and let sit for 3 days, other wise turn screen off
Oct 21, 2009 | Canon PowerShot A430 Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Problem with camera battery
mikeandlenna,
I'm guessing you have had the D80 over a year and past the warranty so you purchased a new battery. If the battery is fully charged and reads partial, check to make sure the contacts are clean (the compartment in the camera might have something on it or hopefully not some corrosion) use a dry q-tip to test and see if anything comes off the contact and on to the q-tip, if that's what it is, then you will be back in business. let me know if that's not it and we can try another route.
randy320sgi
Jan 03, 2009 | Nikon D80 Digital Camera with 18-135mm...
Have a 1989 F250 diesel put a solinoid on the starter and now it just clicks
JU JU Fruit. Your battery is low. You cannot get enough voltage from the system through the ign switch to pull the solinoid in. You have enough voltage to crank the starter, but I am sure this is marginal as well. The starter cranking is all about amps, the solinoid pulling in is more about voltage. Put a volt meter on your battery and I bet it reads less than 12.6 - what a fully charged battery should read.
On the F250, clicking solinoid is also due to low battery voltage. Pull both batteries and have them fully charge and checked. Stores like advance auto parts will dothis for you for free. Clean all of the terminals and reinstall. If batteries are OK, have thew charging system checked also. Again Advance will check it for you
Good Luck
Dec 29, 2008 | 1989 Ford F 250
Batteries brand new rechargables
It could have got wet - they dont like that. Take batteries out - make dry and fully charged Make sure camera if fully dry- put in a warm place to dry slowly- then try
May 11, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Kodak EasyShare C310 Digital Camera Logo
111 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
