Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
It won't stay on
Everytime I turn it on it says 'dew' on the screen and then turns off
  • Anonymous Apr 22, 2009
    Holy cow I figured this was just something that happened to me, but I was gonna get on and see if maybe there was a simple solution, but NOPE, Gosh I may try it anyways because I can't use the camera as it is, but I sure hope I dont' destroy it, thanks for the help
    Problem Solver:
  • 5 Answers
The solder joints to the DEW Sensor are "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
You may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Posted on Feb 27, 2009
  • jamsman363 May 31, 2011
    After years of suffering with this problem, 5 minutes and a soldering iron solved it. Thanks so much for these instructions! It could not have been easier.
Pandigital novel white stuck on blue screen
everytime i turn on my pandigital tablet it goes to blue screen and stays on there, until the battery dies, everytime you turn it on it goes to the blue screen and stay on there what should i do?
Mar 02, 2012 | PANDIGITAL Novel 7
When I turn the camcorder on, DEW shores on the screen, then it moves from the right to left of screen and camcorder shuts down
Moisture is an enemy of any tape based system. The moisture can cause the tape to "stick" to the rotating heads damaging both the tape and heads. This is why there is a "dew" sensor inside the tape compartment. The screen message indicates that the sensor has detected an excess mount of moisture and won't let the unit load a tape until the problem is cleared. Try leaving the unit open and pointing a hair dryer at it from a distance of about 12"-18". The warm dry air should remove any moisture that exists. Should this not resolve the problem, there is a defect in the sensor and it might need to be replaced.
Dan
May 29, 2011 | Sharp Viewcam VL-Z1 Mini DV Digital...
Everytime I turn my camcorder on the screen shows Dew and then it turns off. I left the battery out for a few days but it still is shutting off
There is sensor inside the unit that will detect dew. Moisture inside will cause the tape to adhere to the heads, causing damage to both the tape and heads. With the unit open, try pointing a hair dryer at it from a distance of about 12"-18". The warm air should remove any moisture. Please be careful NOT to aim really hot air into the unit.
If that does not resolve the problem, then either the sensor is defective or the connections to it are broken. The camera will err on the side of not functioning in order to prevent damage.
Keep us posted,
Dan
May 23, 2011 | Sharp Viewcam VL-Z3U Mini DV Digital...
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
"Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Mar 13, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
On screen message "DEW"
DEW on the screen means that there is moisture in set. Leave the unit on for several in a warm dry place. The heat from the picture tube will help dry out the set.
Jan 06, 2009 | Sansui COM3101 13" TV/VCR
Hello...
xiii
Dew Formation
circumstances:
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
one hour.
a plastic bag.
of the room.
Plastic bag
the tape.
Oct 22, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Camcoder
There have been several compaints about this dew issue. I recommend calling Sharp.
Support: (800) 237-4277
May 03, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Where is the reset button on this camcorder, Panasonic PV-DV203 Mini Dv? I can't find it. Also what do it do about everytime i turn the camers on it says "DEW DETECTED EJECT TAPE" There is no...
I haven't used mine for over 2 years because of the mildew detected warning and not being able to find anyone to fix it for me. I just found this on the internet and am going to try it when my battery charges. Seems this is a common error for these palmcorders... good luck! "When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew."
Jan 05, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
224 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
