Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven caught on fire and door now locked-wont open please help!!!!!
  • 198 Answers
Put the oven back into a clean cycle, when finished the door should unlock.
Posted on Feb 20, 2009
I have just finished cleaning my GE self cleanng oven but i can get the lock arm to unlock
oh yes..my oven does the same thing..I always wonder
what would u do if it caught on fire.. !!
mine has a window and I suppose I could break that..
my oven will finally open whenthe oven cools off..
Oct 02, 2016 | GE Kitchen Ranges
My Gibson Oven oven door will not shut because lock mechanism wont retract?
You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
Jul 27, 2016 | Ovens
I have a freestanding GE Profile oven and it randomly beeps an F9 warning, when it's not even being used? Any ideas?
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
Jul 05, 2016 | GE Kitchen Ranges
KitchenAid Superba oven will not open - seems like it is locked (similar to if using self clean option) however, it is not. This is a double oven - the bottom oven opens and operates normally. Top oven...
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
Nov 15, 2017 | KitchenAid Ovens
Self cleaning oven
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 10, 2010 | Tappan TEF242 Electric Kitchen Range
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Fire in oven. Fire Department had to force door
no,you need a new range or a new oven door depending on how bad the fire in the oven was.
Jan 28, 2010 | Hotpoint RGB745 Gas Kitchen Range
Stove top fire , cleaning my GRXL44 oven,
un plug the range and after 5 min plug back in . the oven should be off but the oven may still be locked . you can open it with a thin hanger .. the clock can bee replaced and back panel if needed . will need model # to help you with parts & prices ..****
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven door locked and stove wont work turned the oven on to self clean and it just blew cold air.It did not clean and now the door will not open Please help.
I woke up one morning recently with the oven door on "locked." The stove works, but the oven door will not open. As far as I know, nothing in the oven works. The "door" sign shows up on the window where the clock is.
Sep 19, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
