Black line on screen
Hi my conia plazma has a 5mm thik black line on the right of the screen top to botttom and ite 50mm in from the edge can this be fixed
tah
    President:
  • 1,223 Answers
I dont think so it is broken the panel is broken by impact there is nothin much u can do else replacing the panel
Posted on Feb 20, 2009
Crack to hinge and lid of laptop
just be carefull when opening or closeing undo catgh then lift from as close as possible to hinge to stop stress on cracks to close do same.
hope this helps.
Apr 28, 2010 | Computers & Internet
Polaroid PoGo Digital Photo photographs streaky with purple edge
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
Dec 13, 2009 | Polaroid PoGo Digital Photo Printer
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
Jul 28, 2009 | Televison & Video
Changing paper on HP Designjet 5500 Plotter
Step 1. Install a roll of paper on the spool, and install the spool on the printer. The fixed end of the spool should be on your right side as you face the printer. The paper should come off the top of the roll.
step 2. open the window and support it with the built in support. Lift the blue handle, located just to the right and above the spool adjacent to the black roller.
Step 3 Pull out about a yard of paper and feed it in front of the black roller and in back into the printer. You really don't need to be precise, the path will accept the paper. Keep pushing the paper until it comes up the the top, then pull the paper from the top.
Step 4 If the edge of the paper is cut square just line it up with the front edge of the printer and on the right there is a blue edge guide mark. If the paper has not been cut square then pull it out far enough that it reaches the spool and line the left and right edges up with the roll and also the blue line.
step 5 Lower the window and the handle. The printer will attempt to install the paper. Respond to the questions that appear on the screen and you should be good to go.
I can walk you through it by phone if you need more help.
Jan 28, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Sony Bravia 32in ... vertical gray line on right side of the screen about 4in from the edge of the screen. The line is about 5mm thick and present on all inputs. More visible over brown and blue...
The line should be visible, even with the television off. It is called "de-lamination" of the LCD panel, and occurs in lines, usually vertical, on the screen.
The panel does need to be replaced. You can contact Sony at 1800-222-SONY. They are good people, and should be able to help you.
Hope this helps...
Jan 05, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
