Question about Gateway E-2000 PC Desktop
I forgot my Administrator Password
Until now I was the only user in my computer and I didn't need to use any password, but I remember that I did store one for the admin when I installed windows XP. My roommate asked me to use my computer and after he messed up one of my files I decided to add another user and to block the access to some of the folders. Everything went great and I created the User, changed the folders setting and the way you login to my computer. When I did restart I have 2 users, but I forgot the admin password and I can't login with my user only the new user I created. I can't change anything because the new user have limited access. I can't believe I did something so stupid, please help I am desperate. ENTER THE PASS WORD THA NO WORK i forgot my administrators password
    Novelist:
  • 84 Answers
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Posted on Apr 22, 2009
  • 565 Answers
It's a large file and it has a lot of stuff you don't need (now), but
http://www.ultimatebootcd.com/download.html
is a bootable cd that has a password recovery tool that will get the job done for you.
Posted on Feb 20, 2009
  • 15,935 Answers
If that’s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands. And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/r.../locksmith.asp
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account.
Thanks for using FixYa - a FixYa rating is appreciated!!
  • blueextc3221
    blueextc3221 Feb 20, 2009
    Alternately - at Windows XP Welcom Screen, simply press Ctrl-Alt-Del keys sequence together twice, and you will be shown a Log On to Windows menu which you can specify User Name and Password. In the User Name text box, key in “Administrator” (without quote) and leave the Password field blank. Then press Enter or click on OK. If there is not password protects the Administrator account, or blank password is set, then you will be able to access the Windows with full administrative privileges as Administrator.
Locked out of my computer
Which Password? Bios Password?Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista?Windows 7?OK,if you are running Windows 7, Microsoft tightened security on it so you've gotto have a password reset disk which 99% of the people who own laptops withwindows 7 fail to do. It should be one of the first things you do whenyou buy the laptop. Otherwise, you're faced with reinstalling theOperating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator(hopefully you didn't put a password on it and forgot it too). Once thedesktop appears it will look different, the screen will be darker and the iconsbigger, but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
Jun 07, 2012 | Computers & Internet
Are you sure there is a password? Try leaving the password blank and logging in. Let me know how this goes and if it doesn't work, I'll see what you can do
Jun 24, 2008 | HP Compaq Presario SR2150NX PC Desktop
Need to by pass my password
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Apr 30, 2012 | E-Machines eMachines Desktop PC
I have a emachine w3619, i let my son use it and he changed the login password and cant remember it. and i cant figure out how to get into my computor. how do i go about getting into my computor
OK, if you are running Windows 7, Microsoft tightened security on it so you've got to have a password reset disk which 99% of the people who own laptops with windows 7 fail to do. It should be one of the first things you do when you buy the laptop. Otherwise, you're faced with reinstalling the Operating System or possibly doing a System Recovery.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see the Safe Mode option. Select SAFE MODE and let the computer boot up. When it gets to the User Login screen it will show the Administrator userid and the userid for which you forgot the password. Sign in as the Administrator (hopefully you didn't put a password on it and forgot it too). Once the desktop appears it will look different, the screen will be darker and the icons bigger, but this is normal for safe mode.
When the User Accounts screen opens, click on the userid for which you forgot the password. Select the option to REMOVE PASSWORD.
Apr 28, 2012 | E-Machines eMachines Desktop PC
I Forgot My Password
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen Logon Password?
Apr 26, 2012 | Acer Aspire™ T180 PC Desktop
Read more: administrator forgot password, how can it be deleted or changed??
If you're on Windows 7 or Vista try this:
Mar 30, 2012 | Gateway Computers & Internet
Locked password
Locked Password where? Bios Password? Hard Drive Password? Windows User Account (userid) Password? And which operating system?
If it's the Bios Password, then you will need to remove the CMOS Battery and let the computer sit for a couple of hours. Then put the battery back in and try rebooting. You'll have to go back into the BIOS or Setup to put the correct date and time in but the password should be gone from memory.
If it's the Hard Drive Password, you're kinda out of luck. Hard drives are locked 99% of the time when the computer is stolen. The original owner either locked it while he had possession of it or he could have locked it remotely when it was stolen to keep thieves from getting to sensitive data. The only way around it is to have the original put the password in, or Purchase a new hard drive to put in the computer, reload the operating system, reload the drivers and reload application programs.
If it's the Windows Password for User Account turn off the computer, then turn it on and immediately start hitting the F8 key until you see the SAFE MODE Option. Take the Safe Mode option to boot the computer. When it comes to the login screen it will show you the Administrator account and the Account for which you forgot or don't know the password. Log into the Administrator account (hopefully you didn't password protect it and forgot it). When windows desktop comes up click Start/Control Panel/User Accounts. When the User Accounts window opens up click on the User Account for which you forgot the password then select Remove Password. Reboot the machine
Mar 17, 2012 | Computers & Internet
I forgot my password to my computer and now i can not log in
By removing password on WINDOWS LOG-I, here a tip on how to remove the password.
# Before the windows system boot up press F8 then will appear Windows Configuration command then select SAFE MODE.
# Wait until it comes up to the screen and you will see the 2 USERS "ADMINISTRATOR" in "USERNAME".
# Go to Control Panel and select USER ACCOUNT.
# Click on "USERNAME" then remove the password.
# Restart your COMPUTER and the windows system will direct you to the DESKTOP.
Hope this might help you my instructions. Good luck!
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
Forgot Administrative password
I got the following from the windows help and support:
OPTION 1
Using a password reset disk is the best solution.
  1. If you have typed the wrong password, you'll get a message that says your user name or password is incorrect. When this message appears, click OK.
  2. Click Reset password, and then follow the instructions.
OPTION 2
If there is another administrator account on the computer, that administrator can change the password for the account you can't remember the password for. If you do this, however, you will lose access to any encrypted files, encrypted e‑mail messages, and passwords stored on this account. If you don't have encrypted files or stored passwords, then this option will work for you
OPTION 3
If you don't have a password reset disk or another administrator account, you won't be able to reset the password. If there are no other user accounts on the computer, you won't be able to log on to Windows. In this case, you will need to re-install Windows.
did you have a hint question?
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
478 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
