Question about Standard Horizon HX460S 2-Way Radio
I have hx 460 but no manual. It is in the locked status and I only have access to channel 16. How do I unlock.
  • 3 Answers
Hold down the LAMP button for 1 Second. (Left side next to the Talk button)
Posted on Sep 05, 2012
    Problem Solver:
  • 5 Answers
Most of the time if your handheld is in a locked status, there will be a single button that needs to be held for usually about 3 to 5 seconds to unlock it. Some Standard radios have a botton with a Key symbol. If your's doesn't have a botton like this, try holding each botton for 3 to 5 secs (1 at a time).
Posted on Feb 27, 2009
How do you change the stills function from 4.3 to 16.9 its really not very clear?
Hi
Having looked at the full manual - downloaded from here and savable:
http://tda.panasonic-europe-service.com/docs/2z54662404z3z38916z656ez706466z22zdf06e277f71e6367f9e09db70241478cb0ad23ae/tsn3/data/ALL/HXWA30EG/OI/902781/vqt4x32.pdf
I think you will find that you cannot actually change from 4:3 to 16:9 aspect ratio for a particular pixel sized picture. When you set the pixels for the picture you want, the aspect ratio is set automatically.
For example:
16Megapixels 4608x3456 4:3
12Megapixels 4608x2592 16:9
See page 96 of the manual mentioned above for a full table of Megapixels, size, ratio etc
Therefore changing the picture size from the simple menu changes the aspect ratio but you do not have control of the aspect ratio for each size, in other words you cannot take a 16Megapixel picture at 16:9, it has to be 4:3.
Hope this has been helpful
Cheers
Nov 14, 2014 | Panasonic HX-WA30EB-K Hx-wa30 Upright...
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
Mar 29, 2011 | Uniden BC898T Base Scanner
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
My JVC HX-C6 is locked and i cant get a single cd out of it how do I unlock it?
push the STOP button then lift the CD tray while holding the STOP button. then you release the STOP button, then the tray.
Feb 28, 2009 | JVC HX-C6 Shelf System
All channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Nov 18, 2007 | Radio Shack Pro-2055 Base Scanner
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Standard Horizon HX460S 2-Way Radio Logo
105 people viewed this question
Top Standard Horizon Radio Communications Experts
Iron
Iron
John L radiodude365
Tom Chichester
Are you a Standard Horizon Radio Communication Expert? Answer questions, earn points and help others
