Question about Insignia 42" LCD Flat-Panel HDTV
Crackling noise The sound on my 42' LCD tv seems to crackle every once in a while. It goes away just as fast as it come on. It also doesn't happen all the time either. I was told it may have to do with the temp of the tv. Is that true?
  • 1 more comment
  • skipvj Apr 07, 2009
    I to have an Insignia 42" 1080p Flat-Panel LCD HDTV. Out of the blue it has a clicking noise that last a few seconds and goes away. It's coming from the back left side behind an air vent in the casing. If I knew it was normal I would be fine by it, but I fear it is a warning of some about to fail.
  • Anonymous May 07, 2009
    we have a 42" insignia that after it warms up it crackles on occasion then sounds like it is back feeding through the speakers then
    it doesn't stop
  • eagle4541 May 07, 2009
    we tried that didnt work could speaker connection inside go bad when warmed up?
My flatscreen LG television crackles all the time, what can I do to stop it?
Posted on Dec 05, 2009
The audio crackle stopped when I disconnected the analogue antenna cable, which is not important as we only need it if the satellite goes off line. Ausred.
Posted on Apr 10, 2011
  • 3 Answers
New t.v's don't overheat like old computers. check the audio connections from your cable boxor satellite reciver to your t.v. believe it or not, sometimes the wires just need cleaned. use rubbing alcohol and a q-tip to clean the ends of the cables. let dry for a few seconds and plug them back in. if this does not help let me know.
Posted on Feb 20, 2009
Sanyo 42 lcd tv dp42841 is making a crackling noise and not sound
you must check first the audio speaker if worn out. if ok at this time you will need to check weather the amplifier ic get burnt.
Nov 12, 2012 | Televison & Video
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Crackling noise on tv
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.When it's not able to provide power to the lamp it will flicker,cause the tv to shut on and off .You will need to replace it.Price varies from $40.00 up to $100.00 This procedure is fast and easy.Have a bless one!
Apr 02, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Crackling sound on PS3
the laser is starting to wear out. it cant reda the audio fast enuf to keep up with the visual side of the game resulting in crackling momentary hissing or cutting out of music
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Dec 08, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Feb 21, 2007 | Vizio L37 Television
Insignia 42" LCD Flat-Panel HDTV Logo
841 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
