Question about Zenith C27A24T 27" TV
VCR/DVD prongs broken off in TV
The prongs that attach the wires from the VCR/DVD player to our TV have broken off in the TV part where they are to plug in. I moved our TV and VCR/DVD player and I forgot to unplug the VCR/DVD player from the TV, so when I moved the table they were on, the prongs from the VCR/DVD wires broke off in the TV plug in part.
  • 75 Answers
Unplug the tv then try to drill a real small hole in the broken off part of the cable that is inthe tv, then take a sharp pointed screw and try to thread it into the hole that you drilled if able to get it started then pull out on the screw to see if it will come out. If not able to do it this way you will have to take the back off and some of and see if you can push the broken part out from the inside. Be sure to unplug your tv from (AC) so you dont get hurt. If that dont work then u probley willhave to take to a shop to get fixed.
Posted on Feb 21, 2009
How do I hook it up yo TV. Have red yellow and white three pronged cable, but TV doesn't respond.
hi sounds like u r using RCA cables if u have hooked up to the output on youre vcr & the input sockets on tv .....set you tv to AV INPUT..if vcr & tv r working OK this should work ...good luck.
Sep 08, 2015 | Philips DVP3345V/17 DVD Player/VCR
Symphonic dvd/vcr player
1) you must clean the DVD player, put a clean disk , if you do not have buy it in radio shack.
2) after cleaning if the process do not resolve the problem you must test the following.
3) clean the wires from corrosion +terminal, test the wires from video if is broken or break, repair or replace.
4) if this is o.k
5) test the power supply the voltage for digital is +5Vdc, for Video +15-15vdc. IF this missing repair the power supply.
6) test the VCC in microcontroller.
7) test the OPU optical pick up this contain lasser beam, must read the TOC, if not replace the OPU
8) Test the servomechanism motors a) search b) track c) sledg d) CLV) If there are missing replace or repair.
9) IF you can not resolve this electronic problem go to the repair shop TV for fix. it.
see the block diagram.tight any wires connector very WELL.AND CLEAN WITH CONTACTS CLEANER.
God bless you
Jul 15, 2012 | Philips MWD2205 DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
My DVD/VCR player does not receive power what is wrong and can I get it fixed? The power cord has not cuts, I have tried multiple outlets and still nothing
have you checked to see the prongs/ground aren't loose or broken off?
The cord might be bad, or the power converter inside could be bad. do any lights come on at all?
Aug 09, 2009 | Samsung DVD-V4600 DVD Player/VCR
No sound when playing a tape in the rca vcr player
If it's connected with a scart cable, then there may be a bent pin or broken wire.
Jul 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
The prongs that attach the VCR/DVD player wires to the TV, broke
try twisting it out with a plier. It won't damage the tv as long as you do not bend
Feb 20, 2009 | Zenith C27A24T 27" TV
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Zenith C27A24T 27" TV Logo
424 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
