Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark Ink Cartridge Issue
I have a lexmark x1240 and we replaced the cartridges several months ago and haven't used the printer much since then. Now the printer goes through all of the printing and copying steps but my pages are blank. Do cartridges expire or have a shelf life? My computer is not having a problem communicating with the printer and I'm not sure what else may be causing the problem. Thanks!
  • megax01
    megax01 May 11, 2010
    Once you open a inkjet cartridge then yes they do have a length of time that they will remain operational as there is always a small leakage of ink once opened. However a couple months is not enough time for the ink to drain. Did u try cleaning the print nosseles on the printer using the printer utilities?
    Problem Solver:
  • 19 Answers
Ink cartridges do have a shelf life - usually about two years from manufacturing, but it's more likely that the nozzles have become dry or clogged as result of disuse. You may get things corrected by putting regular rubbing alcohol on a clean soft cloth and gently wiping the contact points between the printer and the cartridge. If that doesn't work, you'll probably have to replace the cartridges.
Posted on Aug 28, 2009
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Was given a Lexmark 1200 series X1240 all in one and cannot determine what type of ink cartridge to use.
The Lexmark X1240 printer uses #16 and #17 for Mono/Black, and #26 and #27 for Color. Hope this helps.
Jun 11, 2010 | Lexmark X1240 All-In-One InkJet Printer
Printer will not work after installing a new ink cartridge?
did you see a piece of plastic stuck on the back of your cartridge?
Mar 21, 2009 | Lexmark C533DN InkJet Printer
Lexmark X1240 cartridge Error
Try a pc reboot or try the owners manual for a reset sequence in the control panel on the printer itself Lexmark provides owners guides and a lot of useful info at thier web site here is the link if you are interested
http://www.lexmark.com/lexmark/site/home/0,6932,204816596_0_0_en,00.html
best luck
Aug 31, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Install Ink Cartridge
Swith on the printer. Open the printer top cover. It is called flap. Now press upwards the cartridge's top end. and lift up that. now take the cartridge out. insert the new cartridge the same way took the cartridge out. put the cartridge layer down. Now close top cover.
Oct 24, 2007 | Lexmark X1240 All-In-One InkJet Printer
Which black cartridge does this need?
Yes you can refill the cartridges. Also Walgreen's refill cartridges now. $10. for black and $15. for colr cartridge refills. I've been using their refills and they work fine. It's less mess that doing it myself. And they use good quality ink... But you can refill them.They also carry universal refill kits at walgreen also. Also the cartridges are not hard to find you can order them at several places online. Google x1240 for sites. Also Staples sell the cartridges.
Sep 25, 2007 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
