Question about Dishwashers
Kenmore 80 series washing machine-top load
I have akenmore washing machine with a 3 button water has 3 levels small,med .large .When i put it to large load it does not fill up all the way .only halfway on a large load .What could my problem be
  • 198 Answers
You will need to replace the pressure switch, Take back off console to get to the switch, there are 3 wires brown, purple and pink, also a hose that attaches to the switch needs to be removed. Switch will cost about 30. dollars
Posted on Feb 20, 2009
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Can't see water leverage
water level needs to be brought up alittle on your amount of level as in small med large loads...
Jun 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\
Good luck.
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 washing machine -water sensor not working
Kenmore is uniformly easy to work on, everything comes off from the front.
There are two 80 models,
on the most common, newer model, the edge trims on the console pop off, there is a phillips screw in each corner, remove the screw, slide the console forward, lift up and flip over.
on the older one the console is released by sliding a putty knife or other blunt blade under the corners of the console to uncatch a clip, lift up flip over
  • ensure air tube is attached (water level sensor operates off air tube from bottom of drum to control body, (bottom is not loose or there is water all over the floor))
  • Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing (usually makes water level lower)
  • ensure wires are connected to control body.
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed - dont shock yourself on the cable connectors
  6. test, adjust, test adjust. (water level switch may need to be flicked hi-med & back to test adjustment
  7. if no effect replace water level sensor body
The water level switch body contains a small spring that is not really up to the job and stretches over years,
do this repair, on call, no parts, takes 15 minutes,, 3-4 times a month
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflowed!!!
The most common cause for this is the water mixing valve plunger sticking. the fix is to replace the mixing valve. Not so common is a defective water level pressure switch. Same fix, replace the switch. Really rare is a small leak in the tube from the tub to the pressure switch.
Feb 06, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
