Question about Zenith C27A24T 27" TV
The prongs that attach the VCR/DVD player wires to the TV, broke
Broke off in the TV. I need to get the prongs out of the TV.
Try twisting it out with a plier. It won't damage the tv as long as you do not bend
Posted on Feb 20, 2009
2 Suggested Answers
  • 74 Answers
SOURCE: VCR/DVD prongs broken off in TV
unplug the tv then try to drill a real small hole in the broken off part of the cable that is inthe tv, then take a sharp pointed screw and try to thread it into the hole that you drilled if able to get it started then pull out on the screw to see if it will come out. If not able to do it this way you will have to take the back off and some of and see if you can push the broken part out from the inside. Be sure to unplug your tv from (AC) so you dont get hurt. If that dont work then u probley willhave to take to a shop to get fixed.
Posted on Feb 21, 2009
How do I hook it up yo TV. Have red yellow and white three pronged cable, but TV doesn't respond.
hi sounds like u r using RCA cables if u have hooked up to the output on youre vcr & the input sockets on tv .....set you tv to AV INPUT..if vcr & tv r working OK this should work ...good luck.
Sep 08, 2015 | Philips DVP3345V/17 DVD Player/VCR
How can I get the long metal piece out of the hole in the TV where you plug in the wires for the dvd
tweesers, or very thin needle nois plyers. be very careful. make sure power is off.
Oct 24, 2014 | Sansui Televison & Video
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Hookin up vcr
just look and connect the RCA chord,yellow wire connect to vcr video out then to the video in in your tv. then the connect rca chord audio out to vcr then to tv audio in, then set the tv to AV
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
Feb 20, 2009 | Zenith C27A24T 27" TV
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Zenith C27A24T 27" TV Logo
73 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
