Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Customer service I have a GE profile refrigerator PSS26SGRDSS,the ice dispensor is not working.I found out that there is a manufacturing defect in this series that the company knew about.They did not let the customers know.My refrigerator is just over 3 years old and the company is refusing to repair it free.I think their customer service is very poor and even told me they called me several times and that is not true.For the sucessess of the company be honest in your dealings because everyone is as as intelligent as you are or more.I will not reccommend GE refrigerators to anyone.
  • 1 more comment
  • amonc Mar 07, 2009
    I have the same problem pss26sgrdss. I replaced the front panel wx10415. still doesn't work. any suggestions?
  • mcjurys Apr 03, 2009
    Ice dispenser on P2226SGRD does not work in either crushed or cubed mode. Ice maker works when arm is pressed for ice, the green light on front panel dims but no sounds and no dispensing...
  • tsvoboda Apr 19, 2009
    Our ice maker quit working today. The light at the dispense panel dims when the dispense door opens, but the motor makes no effort to turn. I pulled out the bin and the motor is not jambed (turns smoothly by hand)
    I'm wondering if there is a loose plug or something. Seems strange that the motor would suddenly stop one day. Guess I'll be dismantling the unit if I don't find a fix online.
    Novelist:
  • 117 Answers
Everyone has their opinions. Been repairing for a long time and in all honesty, I don't think we ever had a call with your problem on your model. Perhaps was a molding issue with the housing and it was missed by the manufacture and passed through the assembly line un-noticed. Don't get me wrong, all maufactures have problems but the company in General is a good Company. Perhaps you should give them one more time and call again, speaking with soemone higher up the echelon. When a rep answers, kindly tell the you would like to speak with their supervisor. The people you speak with did not make your refrigerator and the problem is not theirs personally. With the right approach, I am positive your issue can be resolved. A final note...expect to pay money as the warranty is only 1 year and you are into the third year. Good Luck, Eric Campion
Posted on Feb 20, 2009
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispensor flap is little warped.
the number for ge parts service is 1-877-959-8688. make sure you have the model # and serial number. if you don't have a manuel or if you have one that covers more than one model in it than you have to look for a little black most likely silver plate wich will have that info on it. if it's not on the inside or front of fridge anywhere you will have to pull it out from the wall because it will be on the back of it. hope i helped you.
Aug 15, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Dispensor not working
Check the electrical connector at the bottom of the freezer door , this can corrode and develop a poor connection
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Dec 22, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
306 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
