Question about EliteGroup K7SEM Motherboard
On boot up computer keeps restarting with a single beep motherboard model- k7sem elite group
  • 1,031 Answers
The symptom you're describing my be a classic Gigabyte response to bad memory. First of all, go into bios, make sure your RAM voltage and timings are set correctly. If they are correct, you likely have a bad stick of RAM. Remove one stick, test the system, if the problem persists, swap sticks and try again
also try this if it continues Right click My Computer click Properties -> Advanced -> Startup and Recovery. Uncheck Automatically restart. It should give you a blue screen that may give you some indication as to the cause.
Posted on Feb 20, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 20, 2009
    hope this helps pls do let me know
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Feb 06, 2011 | Abit AV8 Motherboard
BOOTS FINE,SETUP CONFIG FINE, F10 TO RESTART NO CHANGES SAVED, PLS HELP
For that you need to change your cmos cell it gives voltage to mother bord flash memory so it save settings.
then save settings .
Aug 12, 2009 | EliteGroup K7SEM Motherboard
Single Beep on boot... repeats after 2-3 seconds, no video
This is a tough one. On some system bioses one beep means a problem with the RAM. On most it means a succesful POST. Are you getting any video? Have you tried booting to a boot disk? Have you tried a new hard drive? Have you tried to clear the CMOS? Good Luck!
Jun 27, 2009 | Dell Dimension 4700 PC Desktop
Hardlocked;beeping and red light on motherboard;will not restart
Something on the motherboard has failed, and the RED light confirms it.
Turn your computer off.
Remove ALL of the RAM. Turn your computer on.
Do all the fan(s) start to spin?
Do you get the _same_ "beeps" as before, or some different pattern of beeps?
If it has more than one stick of RAM (and the RAM is _NOT_ labelled 'DDR2'),
then remove all but one stick of RAM, turn your computer on, and try to reboot.
Same beeps?
Turn your computer off, try a different single (or pair of) sticks of RAM.
Caution: before doing any of the above, your computer could be within the "WARRANTY" period,
i.e., it could be fixed/replaced for free!
May 26, 2009 | Abit GD8 Motherboard
Booting
The PC is recycling. Check the motherboard for blown capacitors, especially around the processor. Also, test the power supply and change it if necessary. If all this fails to yeaild results, the CPU could be causing problems, also check the RAM.
Mar 18, 2009 | EliteGroup K7SEM Motherboard
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
DRIVERS NEEDED
Go to this page: http://www.ecsusa.com/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=9
Pick motherboad in the first box in the upper left.
Then pick Socket 462 in the next box
Then pick K7SEM
Then the board's version (should be written on the board next to K7SEM or onscreen when you first boot)
You will be taken to this board's drivers page.
Jan 23, 2008 | EliteGroup K7SEM Motherboard
Speed of ram to buy
if its just sdram, then pc133 is the fastest speed as its single data ram or you can fit pc100 although these are both hard to come by and expensive. The max amount of memory you can use is 1GB See below
Sep 07, 2007 | EliteGroup K7SEM Motherboard
EliteGroup K7SEM Motherboard Logo
219 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
