Question about Acer Aspire 5500 5570-2609 Laptop
Wierless router is not working
The wireless router will not turn on, The light will not come on at all. What do I do?
    Novelist:
  • 148 Answers
check the power socket by using some other eqipment if power is coming from the power socket, if it is
mostly in this type if cases the adapter is bad, replace the ac adapter and check,
Further queries are welcome
if you think my solution is helpfull please do rate me
Posted on Feb 20, 2009
Wierless router not responding
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Feb 12, 2012 | NetGear DGN1000 Wireless Router
Does not wierless work in xp computer and 2 ipad.
Are you using a laptop? If not, the computer that you are using should capable of connecting via wireless connection. And the Modem /router should be transmitting wireless signal. If you can successfully connect via wifi, then all of your wireless end devices should be connected via wi fi a as well. check your local network for issue isolation.
Dec 30, 2011 | 2wire (2701HG-B) Wireless Router
Hiee I am using netgear N300 jwnr2000 router. The router worked fine for few days it has suddenly stooped working.Any of my wierless devices are not able to detect my router since the wifi in been...
Unplug both your DSL/Cable Modem, and the Router from power. Wait 30 seconds. Plug in power to DSL/Cable Modem only, and wait for it to connect. then plug in power to Router, and wait for it to start up. Give it about 1 min. If the lights are still not on, you may need to reconfigure your router. If this does not work, connect your cable/DSL modem to your computer directly, and power cycle it again. Once it is online, check to see if you can get online, if you cannot, contact your internet service provider, as you have ruled out a problem with the router.
Dec 28, 2010 | NetGear WNR2000 Wireless Router
What is the WEP key for Belkin Wierless Router f7d201
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Dec 20, 2010 | Belkin Basic Wireless Router
N router/ The blue wierless light is not lit!? unable to connect to my other PC
Push and release the “Reset” button.
The lights on the Router will momentarily flash.
The “Power/Ready” light will begin to blink. When the “Power/Ready” light becomes solid again, the reset is complete
Follow me on Twitter
Jun 08, 2010 | Belkin (F5D8231-4) Wireless Router...
We buy a router but the wierless is lock what should i do to erase the lock when i use my iphone it has a pasword
You will need to check the wireless settings of the router.
Do you have any computer connected to the router ?
If not then you will need to connect the computer to the router and open the set up page of the router.
Check the IP address of the computer and open the set up page of the router.
On this page you will find all the settings of your router.
You can check the wireless network key or the password on this page.
Apr 15, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Have a Wierless-G router can not install, tried 3 times. While installing it has very limited range , pc is 4-5 feet away & couldnt pick it up. Any ideas ???
check the wireless settings of the router. try to change the channel of the wireless network.
SSID broadcast should be enabld on the router. It depends on the computer also.
If your router is old then upgrade the firmware of the router. firmware is the software of your router.
Click here for more information about the router
Mar 27, 2010 | Linksys Wireless-G Broadband Router
How to connect to a wierless network ?
hello you could try this turn the power off to the modem and take the ethernet lead out. at the back of the modem is a reset button press and hold for 30 seconds after that reconnect the ethernet lead and power and re set up again good luck
shaun
Jan 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I just set up wireless router and cant get my ps 3 to connect
Ps3 does not support wierless N, use wireless G works awsome for me.
Dec 21, 2008 | Sony Playstation 3 (PS3) Console
Acer Aspire 5500 5570-2609 Laptop Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
