Question about LG 50PX4DR 50 in. Plasma TV
Screen just suddenly went dark!
Screen just suddenly went dark although you can make some images out in the darkness! We have had this LG 42 inch plasma for approximately 2 years. Is it worth getting fixed or just scrapping it? Cost approx £800 new. Thanks
  • tarheel0123 Feb 23, 2009
    The same thing happened to me.  I turned the TV on that I have had for about 3 years.  I made a soft bang sound and lost the resolution.  I can see a faint picture with dark streaks that appear and disappear all over the screen.  Do I need to junk this or were you able to solve the problem.
    Scholar:
  • 87 Answers
If you can see a faint picture with streaking you most likley have a defective Zsus module Part Number 6871QZH036B Description PWB(PCB) ASSEMBLY,DI List $226.14 Please rate my info
Posted on Feb 20, 2009
I have a LG 50LA6200 LED TV, about 3yrs old. While watching it, the screen suddenly went black, the audio is fine.
In the dark with the set on do you see light if you look through the vent holes in the back?
Oct 19, 2017 | LG Televison & Video
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Have 42 inch LG flat screen...for about 3 years...
Take the back off with no power connected..You should have 2 invertor pcbs..one on the left and one on the right..well the side of the picture you cant see is the same side of the faulty invertor..replace this and this should solve the problem.it is the cheapest option..if not..im afraid is is a new LCD screen unless you are prepared to take it appart and replace backlight bulbs :)
Oct 17, 2009 | LG 42LC2D 42 in. LCD HDTV
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
SCREEN AND POWER CUT
maybe the inverter board for the screen issue- the power issue seems to be LG has power board design flaw- basically last time I looked the power board is manufactured NOT by LG but by H&E ...who designs this stuff??
Dec 15, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 50PX4DR 50 in. Plasma TV Logo
561 people viewed this question
Computer Repairing
Computer Repairing
